The Elephant Man Italian 4Kult Edition
mizu_ger
Post by mizu_ger »
Has anyone had success ripping the Italian 4Kult edition of The Elephant Man? I've submitted the dump twice over the past couple of months, but it's still not supported. Is there something unusual about this disk?
mizu_ger
Re: The Elephant Man Italian 4Kult Edition
Post by mizu_ger »
Bump
Anyone know if there is a problem with thisdisk? It's still not drecrypting. I'm downloading the latest HK fine, so that's not the problem. Is this disk never going to be supported.
BTW, is there a list of disks that cannot be decrypted? even after the dump files have been analysed?
Do you know what version of AACS that disc has? There's one variant of Zombieland 4k that MakeMKV won't yet decrypt: viewtopic.php?f=12&t=20549&start=60#p94204
I have no idea if this disc is in the same boat as that one variant of Zombieland.
mizu_ger
Post by mizu_ger »
dcoke22 wrote:
Sun Feb 21, 2021 11:22 pm
Thanks for pointing me to that thread.
How can I tell the AACS version on this disk? This is all I see in the MakeMKV Info window
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.00
Serial number: KETI8IG3039
Firmware date: 2115-12-09 11:47
Bus encryption flags: 1E
Highest AACS version: 76
Firmware version: 3.00
BD raw metadata read: Partial
Disc Information
Label: THE ELEPHANT MAN
Timestamp: 2020-09-04 17:10:47
Data capacity: 91.52 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
You'd be able to tell from the filename of the AACS dump file MakeMKV creates when it can't decrypt a movie. I also think it'll say what the protection scheme is in the 'source' box, on the left after MakeMKV acknowledges the disc but before you start it doing something.
mizu_ger
Post by mizu_ger »
dcoke22 wrote:
Tue Feb 23, 2021 6:18 pm
Thanks.
The dump filename says v72
Well, I don't think it is in the same boat as Zombieland. Perhaps it has just gotten lost in the shuffle. I presume you're using the latest version of MakeMKV? Versions of MakeMKV prior to 1.12 had some bugs in this space: viewtopic.php?f=12&t=16959
And you're emailing the dump to svq@makemkv.com? viewtopic.php?f=12&t=16883
mizu_ger
Post by mizu_ger »
dcoke22 wrote:
Tue Feb 23, 2021 10:52 pm
Yeah, I'm on the latest version and I've sent the dump file to that address a few times. I've sent in files for other disks over the same period and those have been added.
Not sure what the problem is with this particular one.
mizu_ger
Post by mizu_ger »
Bump again.
Genuinely intrigued about this now. I've submitted the dump 3 times and it's not supported. Is there something about this disk's encryption that can't be defeated? (Is there a way to find this out?) I've tried one of the competitors and it's not working there either.
The database is updating for me fine, so that's not the problem: I've submitted other dumps and those disks are supported now.
Rororororo
Post by Rororororo »
Product: BC-12D2HT
This is old firmware version, the latest available is 3.11 and it's patched, maybe it's worth flashig and trying again?
Firmwares are available here viewtopic.php?f=19&t=19113
since 1.15.1 you can use MakeMKV tools to flash, using this command in Powershell with administration privileges
./makemkvcon64.exe f --all-yes -d “your drive letter here Example: D:" rawflash -i “path to your firmware Example: C:\Users\Downloads/mk-firmware-pack-20200720/MK/ASUS/BC-12D2HT/ASUS-BC-12D2HT-3.11-WM00300-211902271319.bin"
I did it few days ago with my BW-16D1HT drive and it works like a charm.
Video tutorial: https://www.youtube.com/watch?v=jyQV1aPlbow
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
mizu_ger
Post by mizu_ger »
Rororororo wrote:
Thu May 06, 2021 3:30 pm
Product: BC-12D2HT
Thanks for that. I may give it a try, but I don't think that's the problem. I tried 2 other windows rippers (the monkey and the fox) and neither of those worked. The former reported that it automatically sent a logfile and that the disk would be ready to decrypt in 1-2 days. That was a month ago and it still can't decrypt it!
There is something unusual about this particular disk. I'd love to know what the problem is. Is the key hard to decypher? I'm not sure. Is there anyway to find out what the problem is? Is this the only disk that can't be decrypted or are there others? So many questions :D
mizu_ger
Post by mizu_ger »
Working now :D
