Yes I have it working at 100%. It is Microsoft windows that is killing it. It has nothing to do with DVD FAB AI. Its your operating system creating the issues.
Here is what you must to, then it works EXTREMELY well:
First, you must stop windows from doing dumb stuff like shutting down your USB ports, shutting down hard drives, etc. Turning off "sleep mode" does not do it. For windows 10:
Here it is running. I am using a new i5 running north of 4GZ, 12GB ram, my hard drive for windows is not a HDD or a SDD, it is a Samsung 970 EVO M.2 with a read speed of 3,400 MB per sec. Really a SSD that can read write at about 500MB per sec will do fine as this program DOES NOT use a HD the same way a video editing program does. My graphics card is an NVIDIA GEFORCE GTX 1050 ti, so you do need a good card. Follow the specs published by DVD FAB. Their software can communicate with certain bios on graphics cards only. So it is not only about having a card with lots of CUDA cores. That is not how programming code works... So have a good card their software can talk to. It was only about $200 for the card and it runs games very well, like Battle Front star wars, or Red Dead, or Terminator Resistance all on max settings. So here is DVD FAB working to upgrade Charlie Brown christmas on DVD up to 1080p running:
- DVD FAB AI running.jpg (104.25 KiB) Viewed 72755 times
Here are screen shots of the windows settings you must change:
- DVD FAB AI - fix windows 1.jpg (149.61 KiB) Viewed 72755 times
- DVD FAB AI - fix windows 2.jpg (82.08 KiB) Viewed 72755 times
this Make MKV interface will not let me upload all my screen shots. Grrr. I have a list of shots to make it easy for folks.
www.makemkv.com server will only let me upload 3 pics. sorrry.
There are many settings in advanced power management, you must turn ALL OF THEM OFF that you can find. In windows 10 there are like 8-10 settings you must turn off.
Then go into NVIDIA control panel, usually down by your clock. Turn ON "USE reverse telecine".
Now VERY IMPORTANT
Go into your program used to play back videos.
Turn OFF telecine.
Turn OFF any kind of software based "enhancements". All of these are garbage and do not work other than for super low quality things like maybe a tiny web image. For a HDTV if you use any software color or sharpness of any kind it will contribute to poor color, poor edges and will also make stutter.
I have discovered that regardless of having a crazy fast PC, you MUST turn on reverse telecine ONLY ON YOUR HARDWARE graphics card, and TURN OFF TELECINE in your software for playing videos. And turn off any stuff that attempts to improve color or edges in your playback software.
I am playing Blue Rays ripped as mkv files off a drive that spins at 5,400 RPM with absolutely no stutter, and I can click foward, reverse and go to diff points in any movie instantly.
And be REMOVING those horrible, poorly done power manegement things done by windows, your DVD FAB AI will run WITHOUT choking.
If your PC chokes after like 3-4 hours of running AI, it is because your PC is shutting something off while DVD FAB AI is still running. SO it is up to you to turn off all stupid stuff microsoft did for their attempts at power management.
