battlestar galactica which file is the menu?
kyrill
#1 Post by kyrill » Mon Jan 04, 2021 12:35 pm
I bought the newest version of Battlestar galactica complete edition
I only need the menu you see as a first when playing the BD disc and of course the movie. All extra's around it I do not need or want.
But how do I recognize which file on the disk(s) is the menu?
I hope you know :)
Re: battlestar galactica which file is the menu?
#2 Post by Woodstock » Mon Jan 04, 2021 1:59 pm
The only way to have the menu is to rip as a "backup". MKV files do not store menus.
preserve
#3 Post by preserve » Mon Jan 04, 2021 3:53 pm
It depends on if you mean the menu itself as a navigable thing, in which case Woodstock's answer applies, or if for whatever reason you're interested in the elements that the menu is composed of.
If the menu has video running in the background, that video will be on the disc.
In some rare cases, the video of the menu background will have the text rendered as part of it. The LOST television series is one example.
Using: ASUS BW-16D1HT 3.00
#4 Post by Woodstock » Mon Jan 04, 2021 5:02 pm
I had not thought about the video behind the menu... Those generally will require the Minimum Title length to be reduced, as they rarely exceed the default 120 seconds.
kyrill
#5 Post by kyrill » Tue Jan 05, 2021 10:38 am
thx guys but also bad news. The menu put some order in all these 22 disks files The discs are full of "MKV"entries , very hard to decide which one to copy on disk and which one not. There are entries over 20 gig that looks 100% identical to the last MB, so why are they on the same disks as twins?
and the time order to watch them is also hard to find as they seem not be ordered in a logical sequence ppff
To rip as back up is it possible after having done this to remove redundant files of teh backup? redundant meaning all the extra's not part of the main content
preserve
#6 Post by preserve » Tue Jan 05, 2021 11:57 am
Welcome to the world of TV discs, you’ll have to work though the content to determine what’s what, and what order it goes in. I can’t remember for sure but including/excluding Japanese language options may be duplicate playlists in this set. I seem to remember that some episodes have alternate extended versions too?
I have the UK edition of this, if the discs are the same, I might be able to make a big list.
I think you would run into problems if you try to go the backup route and delete stuff out of it, but then again, I usually use MKVs instead of disc backups as the playback method, so I’m not the best to advise on that question.
#7 Post by Woodstock » Tue Jan 05, 2021 2:41 pm
You will definitely want to spend some time with naming. You can do it pre-rip using the steps described here: Changing names with Expert mode enabled
For BG, I divided them by season, with names like "Battlestar Galactica S1 E01-02.mkv". I also put each season in its own directory, but that's just me.
ChrisI
#8 Post by ChrisI » Tue Jan 12, 2021 1:04 am
The 20 Gb titles are the episodes. Rip the ones with chapters, ignore the others.
To match the titles to the correct episode name I use thetvdb and compare things like the writer and director names. Another way to do it is to play the disc in a blu-ray player, selecting the episode from the menu. Play enough so you can identify it, then find the matching title you just ripped.
Just to make sure you get everything:
Use the contents description on the box sleeves to identify which disc has "The Resistance" webisodes. They are all in a single title. (Sorry, I don't remember which disc, but pretty sure it is in Season 3.) The Razor flashbacks are on the same disc as the Razor movie, in the Season 4 box.
A few episodes offer both the aired version and an extended version. Again, use the sleeves to see which ones, and decide if you only want one, or both.
preserve
#9 Post by preserve » Wed Jan 13, 2021 8:32 am
^ Yup, solid advice. Checking the writer and director is also my go-to when the episodes are out of order and lack on screen episode titles, I find it the quickest method (Wikipedia is great for this, if the release doesn’t mention it in a booklet). Watching the start of the episode compared to playing it on a regular player is a good one too.
lordthunder77
#10 Post by lordthunder77 » Thu Jan 25, 2024 7:57 pm
The disc has a small sratch 1 inch on the outer edge brand new in package asked for replacement disk to verify if it was made correctly. some people might get defective discs.
https://www.amazon.com/dp/B09BXZ3DL2?ps ... ct_details
Title #00004.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00010.m2ts' at offset '0'
Title #00002.mpls was skipped
Title #00046.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00000.mpls was added as title #0
File 00052.mpls was added as title #1
Title #01052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00551.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00550.mpls was added as title #2
File 00010.mpls was added as title #3
File 00040.mpls was added as title #4
File 00050.mpls was added as title #5
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00091.m2ts' at offset '0'
Title #00055.mpls was skipped
Title #00000.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts was skipped
Title #00011.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00079.m2ts was added as title #6
Title #00080.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00081.m2ts was added as title #7
File 00083.m2ts was added as title #8
File 00085.m2ts was added as title #9
File 00086.m2ts was added as title #10
File 00087.m2ts was added as title #11
File 00088.m2ts was added as title #12
File 00089.m2ts was added as title #13
File 00090.m2ts was added as title #14
Title #00091.m2ts was skipped
Title #00092.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00094.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Encountered 18 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Saving 1 titles into directory F:/Battlestar Galactica/Battlestar Galactica- Razor
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '23431673856'
udf: node fe/efe failed!
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00079.m2ts' at offset '20241383424'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '20241383424'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00079.m2ts' at offset '20245118976'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '20245118976'
Failed to save title 1 to file F:/Battlestar Galactica/Battlestar Galactica- Razor/Battlestar Galactica- Razor_t01.mkv
Encountered 13 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 2 failed
Last edited by lordthunder77 on Thu Jan 25, 2024 10:29 pm, edited 1 time in total.
#11 Post by Woodstock » Thu Jan 25, 2024 8:49 pm
Looks like read errors. Is your device powered by USB? Do the locations change with different rips?
Those types of errors can appear as the drive spins up past what your USB port can provide power for.
