Brand New DVD - Failed to save title 0
Brand New DVD, wiped clean, tried in 2 different computers (Mac and PC),
Saving 1 titles into directory /Volumes/Public/
DEBUG: Code 4294967295 at MA1n_4Y&'dr&|ToU33D:29393999
DEBUG: Code 0 at Ne:3kp,(FyN,CxPLM45?:29394183
DEBUG: Code 2192557 at Ne:3kp,(FyN,CxPLM45?:29393309
Failed to save title 0 to file /Volumes/Public/title00.mkv
0 titles saved, 1 failed
Is it a defective DVD, should I try to exchange it where I bought it, or is there a setting I might want to try?
Any help is much appreciated
Re: Brand New DVD - Failed to save title 0
Hi!
What's the title and region number of the DVD?
It's an import from Mexico: OV7 - Primera Fila (2010) , and is coded Region "0" (no restriction), and both my two computers are fixed at Region "1".
My PC even has AnyDVD installed.
Turn OFF and exit AnyDVD when using MakeMKV...
Even though I've rip hundreds of DVD's before with AnyDVD activated, and with no problems at all, I did as you said, no AnyDVD activated or in memory in my PC computer. I got this debug message:
Saving 1 titles into directory R:/Pendientes/Renombrar y Reubicar/OV7_PRIMERA_FILA
DEBUG: Code 4294967295 at %E8bm=(3rcY&tpvv,kY:29393999
DEBUG: Code 0 at |/i|nL L~Z~2yo@.:#ln:29394183
DEBUG: Code 2192557 at |/i|nL L~Z~2yo@.:#ln:29393309
Failed to save title 0 to file R:/Pendientes/Renombrar y Reubicar/OV7_PRIMERA_FILA/title00.mkv
I should add that 3 of the 4 tittles that the DVD has, were perfectly copied, and the one with the full feature was ripped to the hard disk up to the 99%, and afterwards deleted.
Remember I've also tried in MacOS X (with no BootCamp or any virtualizer) getting the same results.
I'm guessing it's a poorly mastered disc so, if that's an available option, I'd try that.Is it a defective DVD, should I try to exchange it where I bought it
Of course "mike admin" may have additional insight to offer...
- Contact:
The error shows a corrupted audio track. There is no workaround.
Setarip_old & Mike admin: I sure do appreciate your help. Everything makes sense.
Keep up the great job you're doing!!!
Thanks again
Thanks again
You're quite welcome ;>}Setarip_old & Mike admin: I sure do appreciate your help.
