The Jungle Book 2016 3d
rodrigo081089
When i opened it with makemkv it does not show the video file with the main movie.
preserve
Re: The Jungle Book 2016 3d
That's very strange. I have no issues with this disc, from the US Collector's Edition (I imagine discs from other regions are similar). Are you using the latest version of MakeMKV, 1.15.4?
This is what I see when I start MakeMKV with the 3D Blu-ray in my drive:
And this is what I see when I open the disc:
Can you confirm the Protection and Disc Information specs as shown in my first screenshot?
Please also see this post and post the resulting scans.
Using: ASUS BW-16D1HT 3.00
rodrigo081089
My source is already ripped into the folders. But in the folders i see the right size.
I tried with other 3d disc and is ok.
MakeMKV v1.15.4 win(x64-release) started
The program can't find any usable optical drives.
AACS directory not present, assuming unencrypted disc
Title #00003.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00020.mpls was added as title #0
Title #00021.mpls has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.mpls has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00064.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00065.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00066.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00067.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00068.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.mpls(1) has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00180.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00181.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00182.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00550.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00560.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00561.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00562.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00563.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00564.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00565.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00566.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00567.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00568.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00570.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00571.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00572.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00573.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00574.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00575.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00576.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00577.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00578.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #1
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title #00807.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00808.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00135.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00145.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00147.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00150.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00152.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00154.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00156.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00158.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00160.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00180.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00181.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00307.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00308.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00309.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00310.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00311.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00313.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00314.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00318.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00319.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00320.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00321.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00328.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation successfully completed-
preserve
This is the correct playlist for this disc.
Is your "source" a MakeMKV backup made from the original disc?
If yes, can you go back to the disc, and try opening the disc itself?
If no, then that's your problem - you have a bad source.
rodrigo081089
Yes, I can open it tomorrow because im using anydesk now and i cant put in the driver.
preserve
Sure, please try opening the disc and let us know if it works!rodrigo081089 wrote: Sun Jan 03, 2021 2:16 am Yes, I can open it tomorrow because im using anydesk now and i cant put in the driver.
rodrigo081089
With the disc works fine, thanks
MajinDustin
I'm having a similar issue, I've tried cleaning the disc, power cycling, and I've attempted backing up the disc several times, can anyone explain what these errors mean please?
The error sequence meaning actually depends on your drive, MajinDustin, and it's not specific to this title.
If you're using a USB-powered drive, the most likely cause is that the drive is being spun up faster than the power available can support. The drive resets, and the operating system thinks it is off line.
For internal drives, the most likely cause is the drive is trying "too hard" to read a bad sector. While it is trying to get valid data, it stops talking to the OS, and the OS thinks it is off line.
The fact that MakeMKV continues on says that, eventually, it was able to read some of the problematic sector(s), then it hit an area where the drive couldn't read it.
MajinDustin
This is an internal drive, so you're saying it's a disc issue, correct? I haven't tried the disc on another drive yet, but I suppose I can do that to confirm. Also thanks for the response!Woodstock wrote: Thu Apr 08, 2021 3:17 pm The error sequence meaning actually depends on your drive, MajinDustin, and it's not specific to this title.
Also note that "clean" is a relative term. Some of the things that make a disk "dirty" as far as the laser is concerned look perfectly fine to the naked eye.
