Being Asked To Start Eval Period Every Time
ImSpartacus
Post by ImSpartacus »
I've been using MakeMKV for a couple years to casually watch Blu Rays from my local public library on my Windows 7 desktop PC and it's been fantastic. Major kudos to the dev team.
Recently, every time I start up MakeMKV, I'm asked to start a new 30 day evaluation period. After clicking "yes", MakeMKV works fine and will successfully rip the Blu Ray, but the next time I use MakeMKV (sometimes minutes after), it'll ask to start up the same evaluation period. How can I get an evaluation period to actually "start"?
That wouldn't be a big deal, however I'm just a casual user that isn't interested in permanently storing rips of Blu Rays. Therefore, I rigged up some simple symbolic links VLC (for Windows) to use MakeMKV's libmmbd.dll for its libaacs.dll & libbdplus.dll files. That way, VLC can just play the Blu Rays in real time. Historically, I need to start up MakeMKV after entering a new beta key in order to "start" the new evaluation period. Then I can use VLC to my heart's content. So that's why it's important for me to figure out how to actually "start" the evaluation period.
I appreciate the assistance from the community!
Re: Being Asked To Start Eval Period Every Time
The Bluray functionality has different rules than DVD functionality, because it's the part of MakeMKV that require the most frequent updating. That's why it has a 30-day limit on evaluation, but it USUALLY counts down from 30, after your initial use.
There are really only two solutions to keeping the message from popping up - registering, and leaving MakeMKV running all the time.
The way you're running it now, it starts MakeMKV each time VLC asks for its help, and shuts it down when VLC is done. By starting it and leaving it running, you only get one start-up message.
ImSpartacus
Woodstock wrote:The Bluray functionality has different rules than DVD functionality, because it's the part of MakeMKV that require the most frequent updating. That's why it has a 30-day limit on evaluation, but it USUALLY counts down from 30, after your initial use.
Has it always been this way?
My setup was working pretty well up until maybe a couple months ago.
Woodstock wrote:There are really only two solutions to keeping the message from popping up - registering, and leaving MakeMKV running all the time.
Shortly before posting this, I tried to start up MakeMKV and then run VLC to play a Blu Ray (specifically "How To Be Single," but it generally happens with all Blu Ray) while MakeMKV was idling in the background. I had already clicking the "yes" dialog box to begin the evaluation period. I still got the same error message in VLC (but again, MakeMKV, itself, is working great and I'm ripping it at the moment).
But honestly, I'm still partially satisfied that it's even working. MakeMKV obviously doesn't owe me anything, lol.
I'd suggest sending an email to support@makemkv.com , reference this topic, and ask Mike directly. He's not here every day.
forresthopkinsa
Post by forresthopkinsa »
I don't mean to necro but I'm having this same problem right now.
Using MakeMKV 1.15.0, every time I close the program the Evaluation Period is forgotten. I have to start a new trial each time I run it. Like @OP this wouldn't be a problem except that it makes the VLC integration unusable. I'm getting the exact same errors.
Windows 10 x64
VLC 3.0.8
log from running makemkv: https://pastebin.com/PDbNdQYF
log from running vlc: https://pastebin.com/zY6FRLJx
jonghotti
Post by jonghotti »
I've got licenses for sale at 25% off regular price ($37.50) if you cheapskates can't afford the $50 that is regular price :-)
MaximRecoil
Post by MaximRecoil »
forresthopkinsa wrote:
Wed Mar 18, 2020 6:22 am
Open MakeMKV, click on Help > Register, and then enter the temporary beta key that's provided by mike admin in this regularly updated post:
viewtopic.php?f=5&t=1053
The current key is good until the end of October. Once the key is entered you no longer get the evaluation period popup and you won't have any problems with VLC integration.
forresthopkinsa
MaximRecoil wrote:
Fri Sep 04, 2020 12:31 pm
Sorry I didn't reply sooner, but this was exactly what I needed. Funnily enough, I always accidentally end up back on this page when I'm running into this problem and Googling it thinking, "How did I solve this before?"
Someday I'll learn. For now, I'll just keep consulting your advice every time. Thanks!
jonghotti
Post by jonghotti »
And I still have licenses for 25% off for when and if you feel like contributing towards the further development of the software you’ve been enjoying for free for years .
forresthopkinsa
Here I am, back at this thread once again. Sigh.
jonghotti wrote:
Sat Jan 02, 2021 11:56 pm
And where, do tell, can I buy it at full price?
viewtopic.php?f=1&t=24722&p=106256#p106256
In regards to buying MakeMKV, in March, Mike said, "Hopefully soon :) It is really an ugly technical issue that will be solved eventually."
jonghotti
Post by jonghotti »
Only a handful left here.
