Warning on install of 1.15.4 - Linux mint 19.3
Autumnstone
Post by Autumnstone » Sat Jan 02, 2021 12:27 am
I have just freshly installed Linux mint 19.3
Trying to install the -oss package I got these warnings
(whole transcript to .configure and make
kx@kx ~/MKV/makemkv-oss-1.15.4 $ ./configure
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... x86_64-pc-linux-gnu
checking how to print strings... printf
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking for gawk... gawk
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /bin/dd
checking how to truncate binary pipes... /bin/dd bs=4096 count=1
checking for mt... mt
checking if mt is a manifest tool... no
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking for -objcopy... no
checking for objcopy... objcopy
checking for -ld... /usr/bin/ld -m elf_x86_64
checking for a BSD-compatible install... /usr/bin/install -c
checking whether g++ supports C++11 features by default... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for compress2 in -lz... yes
checking openssl/opensslconf.h usability... yes
checking openssl/opensslconf.h presence... yes
checking for openssl/opensslconf.h... yes
checking for AES_encrypt in -lcrypto... yes
checking expat.h usability... yes
checking expat.h presence... yes
checking for expat.h... yes
checking for XML_ParserCreate in -lexpat... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for ffmpeg... yes
checking whether LIBAVCODEC_VERSION_MAJOR is declared... yes
checking LIBAVCODEC_VERSION_MAJOR... 57
checking whether avcodec_send_frame is declared... yes
checking for AVFrame.channels... yes
checking for av_log_format_line... yes
checking for enum AVCodecID... yes
checking whether AV_CODEC_ID_NONE is declared... yes
checking for AVCodecParserContext.duration... yes
checking whether AV_CH_TOP_BACK_CENTER is declared... yes
checking for av_codec_iterate... no
checking for qt5... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating libffabi/src/ffabicfg.h
config.status: executing libtool commands
kx@kx ~/MKV/makemkv-oss-1.15.4 $ make
mkdir -p out
g++ -g -O2 -g -O2 -D_linux_ -D_REENTRANT -shared -Wl,-z,defs -oout/libdriveio.so.0.full -I./libdriveio/inc libdriveio/src/infolist.cpp libdriveio/src/scsihlp.cpp libdriveio/src/srlist.cpp libdriveio/src/stdquery.cpp libdriveio/src/tipclient.cpp libdriveio/src/tipcommon.cpp libdriveio/src/tipserver.cpp \
-fPIC -Xlinker -dy -Xlinker --version-script=libdriveio/src/libdriveio.vers \
-Xlinker -soname=libdriveio.so.0 -lc -lstdc++
objcopy --strip-all --strip-debug --strip-unneeded --discard-all out/libdriveio.so.0.full out/libdriveio.so.0
mkdir -p tmp
echo "#define BUILDINFO_ARCH_NAME \"x86_64-linux-gnu\"" >> tmp/gen_buildinfo.h
echo "#define BUILDINFO_BUILD_DATE \"Sat 2 Jan 11:18:14 AEDT 2021\"" >> tmp/gen_buildinfo.h
mkdir -p tmp/libabi/src/
gcc -c -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -otmp/libabi/src/ossl_aes.c.o -I./libabi/inc -I./libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/x86_64-linux-gnu -fPIC libabi/src/ossl_aes.c
gcc -c -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -otmp/libabi/src/ossl_sha.c.o -I./libabi/inc -I./libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/x86_64-linux-gnu -fPIC libabi/src/ossl_sha.c
gcc -c -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -otmp/libabi/src/ossl_ec.c.o -I./libabi/inc -I./libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/x86_64-linux-gnu -fPIC libabi/src/ossl_ec.c
gcc -c -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -otmp/libabi/src/zlib.c.o -I./libabi/inc -I./libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/x86_64-linux-gnu -fPIC libabi/src/zlib.c
gcc -c -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -otmp/libabi/src/xpat.c.o -I./libabi/inc -I./libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/x86_64-linux-gnu -fPIC libabi/src/xpat.c
gcc -c -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -otmp/libabi/src/libm.c.o -I./libabi/inc -I./libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/x86_64-linux-gnu -fPIC libabi/src/libm.c
mkdir -p tmp/libffabi/src/
gcc -c -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -otmp/libffabi/src/ffabi.c.o -I./libabi/inc -I./libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/x86_64-linux-gnu -fPIC libffabi/src/ffabi.c
gcc -c -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -otmp/libffabi/src/mlp.c.o -I./libabi/inc -I./libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/x86_64-linux-gnu -fPIC libffabi/src/mlp.c
gcc -c -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -otmp/libffabi/src/log.c.o -I./libabi/inc -I./libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/x86_64-linux-gnu -fPIC libffabi/src/log.c
gcc -c -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -otmp/libffabi/src/audio_convert.c.o -I./libabi/inc -I./libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/x86_64-linux-gnu -fPIC libffabi/src/audio_convert.c
gcc -c -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -otmp/libffabi/src/audio_mix.c.o -I./libabi/inc -I./libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/x86_64-linux-gnu -fPIC libffabi/src/audio_mix.c
gcc -c -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -otmp/libffabi/src/audio_mix_matrix.c.o -I./libabi/inc -I./libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/x86_64-linux-gnu -fPIC libffabi/src/audio_mix_matrix.c
mkdir -p out
g++ -g -O2 -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -shared -Wl,-z,defs -oout/libmakemkv.so.1.full -I./libebml/inc -DEBML_NO_READ -DEBML_STRICT_API -DEBML_DEBUG \
-I./libmatroska/inc -I./libmakemkv/inc -I./sstring/inc -I./makemkvgui/inc -I./libabi/inc \
-I./libffabi/inc libebml/src/EbmlBinary.cpp libebml/src/EbmlContexts.cpp libebml/src/EbmlCrc32.cpp libebml/src/EbmlDate.cpp libebml/src/EbmlDummy.cpp libebml/src/EbmlElement.cpp libebml/src/EbmlFloat.cpp libebml/src/EbmlHead.cpp libebml/src/EbmlMaster.cpp libebml/src/EbmlSInteger.cpp libebml/src/EbmlString.cpp libebml/src/EbmlSubHead.cpp libebml/src/EbmlUInteger.cpp libebml/src/EbmlUnicodeString.cpp libebml/src/EbmlVersion.cpp libebml/src/EbmlVoid.cpp libebml/src/IOCallback.cpp libebml/src/MemIOCallback.cpp libmatroska/src/FileKax.cpp libmatroska/src/KaxAttached.cpp libmatroska/src/KaxAttachments.cpp libmatroska/src/KaxBlock.cpp libmatroska/src/KaxBlockData.cpp libmatroska/src/KaxCluster.cpp libmatroska/src/KaxContexts.cpp libmatroska/src/KaxCues.cpp libmatroska/src/KaxCuesData.cpp libmatroska/src/KaxInfoData.cpp libmatroska/src/KaxSeekHead.cpp libmatroska/src/KaxSegment.cpp libmatroska/src/KaxTracks.cpp libmatroska/src/KaxVersion.cpp libmatroska/src/KaxSemantic.cpp libmakemkv/src/ebmlwrite.cpp libmakemkv/src/libmkv.cpp libmakemkv/src/version.cpp libmakemkv/src/world.cpp libmakemkv/src/stdstring.cpp sstring/src/sstring.cpp makemkvgui/src/api_linux.cpp libabi/src/sys_linux.cpp makemkvgui/src/spawn_posix.cpp \
tmp/libabi/src/ossl_aes.c.o tmp/libabi/src/ossl_sha.c.o tmp/libabi/src/ossl_ec.c.o tmp/libabi/src/zlib.c.o tmp/libabi/src/xpat.c.o tmp/libabi/src/libm.c.o tmp/libffabi/src/ffabi.c.o tmp/libffabi/src/mlp.c.o tmp/libffabi/src/log.c.o tmp/libffabi/src/audio_convert.c.o tmp/libffabi/src/audio_mix.c.o tmp/libffabi/src/audio_mix_matrix.c.o \
-DHAVE_BUILDINFO_H -Itmp \
-fPIC -Xlinker -dy -Xlinker --version-script=libmakemkv/src/libmakemkv.vers \
-Xlinker -soname=libmakemkv.so.1 -lc -lstdc++ -lcrypto -lz -lexpat -lavcodec -lavutil -lrt -lm -lrt
objcopy --strip-all --strip-debug --strip-unneeded --discard-all out/libmakemkv.so.1.full out/libmakemkv.so.1
mkdir -p tmp
/usr/lib/qt5/bin/moc -o tmp/moc_mainwnd.cpp makemkvgui/src/mainwnd.h
mkdir -p tmp
/usr/lib/qt5/bin/moc -o tmp/moc_logtext.cpp makemkvgui/src/logtext.h
mkdir -p tmp
/usr/lib/qt5/bin/moc -o tmp/moc_dirselectbox.cpp makemkvgui/src/dirselectbox.h
mkdir -p tmp
/usr/lib/qt5/bin/moc -o tmp/moc_aboutbox.cpp makemkvgui/src/aboutbox.h
mkdir -p tmp
/usr/lib/qt5/bin/moc -o tmp/moc_settingdlg.cpp makemkvgui/src/settingdlg.h
mkdir -p tmp
/usr/lib/qt5/bin/moc -o tmp/moc_backupdlg.cpp makemkvgui/src/backupdlg.h
mkdir -p tmp
/usr/lib/qt5/bin/moc -o tmp/moc_lineeditk.cpp makemkvgui/src/lineeditk.h
mkdir -p tmp
/usr/lib/qt5/bin/moc -o tmp/moc_dvdbox.cpp makemkvgui/src/dvdbox.h
mkdir -p tmp
/usr/lib/qt5/bin/moc -o tmp/moc_drivebox.cpp makemkvgui/src/drivebox.h
mkdir -p tmp
/usr/lib/qt5/bin/moc -o tmp/moc_toolbuttonp.cpp makemkvgui/src/toolbuttonp.h
mkdir -p tmp
/usr/bin/ld -m elf_x86_64 -r -b binary -z noexecstack -o tmp/image_data.o makemkvgui/bin/image_data.bin
mkdir -p out
g++ -g -O2 -g -O2 -D_linux_ -fPIC -oout/makemkv.full -I./makemkvgui/inc -I./libmakemkv/inc -I./sstring/inc \
-I./libdriveio/inc -I./libabi/inc makemkvgui/src/aboutbox.cpp makemkvgui/src/client.cpp makemkvgui/src/dirselectbox.cpp makemkvgui/src/logic.cpp makemkvgui/src/logtext.cpp makemkvgui/src/main.cpp makemkvgui/src/mainwnd.cpp makemkvgui/src/marshall.cpp makemkvgui/src/progress.cpp makemkvgui/src/scsiinfo.cpp makemkvgui/src/settingdlg.cpp makemkvgui/src/uisync.cpp makemkvgui/src/viteminfo.cpp makemkvgui/src/margui.cpp makemkvgui/src/backupdlg.cpp makemkvgui/src/lstring.cpp makemkvgui/src/notify.cpp makemkvgui/src/str/en_utf16.cpp makemkvgui/src/image.cpp makemkvgui/src/abutton.cpp makemkvgui/src/lineeditk.cpp makemkvgui/src/dvdbox.cpp makemkvgui/src/drivebox.cpp makemkvgui/src/toolbuttonp.cpp makemkvgui/src/api_posix.cpp makemkvgui/src/api_linux.cpp makemkvgui/src/sem_posix.cpp makemkvgui/src/spawn_posix.cpp makemkvgui/src/logic_posix.cpp libabi/src/sys_linux.cpp makemkvgui/src/notify_linux.cpp makemkvgui/src/image_linux.cpp tmp/image_data.o tmp/moc_mainwnd.cpp tmp/moc_logtext.cpp tmp/moc_dirselectbox.cpp tmp/moc_aboutbox.cpp tmp/moc_settingdlg.cpp tmp/moc_backupdlg.cpp tmp/moc_lineeditk.cpp tmp/moc_dvdbox.cpp tmp/moc_drivebox.cpp tmp/moc_toolbuttonp.cpp \
sstring/src/sstring.cpp libdriveio/src/srlist.cpp \
-I/usr/include/x86_64-linux-gnu/qt5/QtWidgets -I/usr/include/x86_64-linux-gnu/qt5 -I/usr/include/x86_64-linux-gnu/qt5/QtGui -I/usr/include/x86_64-linux-gnu/qt5 -I/usr/include/x86_64-linux-gnu/qt5/QtDBus -I/usr/include/x86_64-linux-gnu/qt5 -I/usr/include/x86_64-linux-gnu/qt5/QtCore -I/usr/include/x86_64-linux-gnu/qt5 -lc -lstdc++ \
-lQt5Widgets -lQt5Gui -lQt5DBus -lQt5Core -lpthread -lz -lrt
In file included from makemkvgui/src/aboutbox.h:18:0,
from makemkvgui/src/aboutbox.cpp:15:
./makemkvgui/inc/lgpl/aproxy.h:74:32: warning: unknown option after ‘#pragma GCC diagnostic’ kind [-Wpragmas]
#pragma GCC diagnostic ignored "-Waddress-of-packed-member"
In file included from makemkvgui/src/client.cpp:15:0:
In file included from makemkvgui/src/qtapp.h:19:0,
from makemkvgui/src/dirselectbox.h:19,
from makemkvgui/src/dirselectbox.cpp:16:
In file included from makemkvgui/src/mainwnd.h:19:0,
from makemkvgui/src/logic.cpp:15:
from makemkvgui/src/logtext.cpp:17:
In file included from makemkvgui/src/main.cpp:16:0:
from makemkvgui/src/mainwnd.cpp:16:
In file included from makemkvgui/src/marshall.cpp:15:0:
from makemkvgui/src/progress.cpp:16:
from makemkvgui/src/scsiinfo.cpp:15:
In file included from makemkvgui/src/settingdlg.h:19:0,
from makemkvgui/src/settingdlg.cpp:16:
from makemkvgui/src/uisync.cpp:16:
from makemkvgui/src/viteminfo.cpp:15:
In file included from makemkvgui/src/margui.cpp:15:0:
In file included from makemkvgui/src/backupdlg.h:19:0,
from makemkvgui/src/backupdlg.cpp:16:
In file included from makemkvgui/src/lstring.cpp:15:0:
from makemkvgui/src/notify.cpp:15:
from makemkvgui/src/image.cpp:15:
from makemkvgui/src/abutton.cpp:16:
In file included from makemkvgui/src/dvdbox.h:19:0,
from makemkvgui/src/dvdbox.cpp:15:
In file included from makemkvgui/src/drivebox.h:18:0,
from makemkvgui/src/drivebox.cpp:15:
from makemkvgui/src/toolbuttonp.cpp:16:
In file included from makemkvgui/src/api_posix.cpp:15:0:
In file included from makemkvgui/src/sem_posix.cpp:15:0:
from makemkvgui/src/logic_posix.cpp:15:
from makemkvgui/src/notify_linux.cpp:15:
from makemkvgui/src/image_linux.cpp:15:
In file included from tmp/../makemkvgui/src/mainwnd.h:19:0,
from tmp/moc_mainwnd.cpp:9:
In file included from tmp/../makemkvgui/src/qtapp.h:19:0,
from tmp/../makemkvgui/src/dirselectbox.h:19,
from tmp/moc_dirselectbox.cpp:9:
In file included from tmp/../makemkvgui/src/aboutbox.h:18:0,
from tmp/moc_aboutbox.cpp:9:
In file included from tmp/../makemkvgui/src/settingdlg.h:19:0,
from tmp/moc_settingdlg.cpp:9:
In file included from tmp/../makemkvgui/src/backupdlg.h:19:0,
from tmp/moc_backupdlg.cpp:9:
In file included from tmp/../makemkvgui/src/dvdbox.h:19:0,
from tmp/moc_dvdbox.cpp:9:
In file included from tmp/../makemkvgui/src/drivebox.h:18:0,
from tmp/moc_drivebox.cpp:9:
objcopy --strip-all --strip-debug --strip-unneeded --discard-all out/makemkv.full out/makemkv
mkdir -p out
g++ -g -O2 -g -O2 -D_linux_ -D_REENTRANT -shared -Wl,-z,defs -oout/libmmbd.so.0.full -I./makemkvgui/inc -I./libmmbd/inc -I./libdriveio/inc \
-I./libmakemkv/inc -I./sstring/inc -I./libabi/inc makemkvgui/src/client.cpp makemkvgui/src/marshall.cpp libmmbd/src/marmmbd.cpp libmmbd/src/nstring.cpp libmmbd/src/mmbd.cpp libmmbd/src/mmconn.cpp libmmbd/src/mmbdipc.cpp libmmbd/src/utf8.cpp libmmbd/src/aacs.cpp libmmbd/src/bdplus.cpp libmmbd/src/crypto_ossl.cpp makemkvgui/src/api_posix.cpp makemkvgui/src/api_linux.cpp makemkvgui/src/sem_posix.cpp makemkvgui/src/spawn_posix.cpp sstring/src/sstring.cpp \
-fPIC -Xlinker -dy -Xlinker --version-script=libmmbd/src/libmmbd.vers \
-Xlinker -soname=libmmbd.so.0 -lc -lstdc++ -lrt -lpthread -lcrypto
In file included from libmmbd/src/marmmbd.cpp:21:0:
In file included from libmmbd/src/nstring.cpp:21:0:
In file included from libmmbd/src/mmconn.h:22:0,
from libmmbd/src/mmbd.cpp:22:
from libmmbd/src/mmconn.cpp:21:
In file included from libmmbd/src/utf8.cpp:22:0:
objcopy --strip-all --strip-debug --strip-unneeded --discard-all out/libmmbd.so.0.full out/libmmbd.so.0
type "sudo make install" to install
I bailed at this point and just installed 1.15.3 which installed just fine
I'm not sure if it's a package my computer lacks, or if it's an issue with the new build, and even if it matters
Autumnstone
wmcclain
Re: Warning on install of 1.15.4 - Linux mint 19.3
Post by wmcclain » Sat Jan 02, 2021 3:18 pm
What do you get for:
gcc -v
