Harry Potter and the Sorcerer's Stone - Correct MPLS
EZRyde
Post by EZRyde » Sun Aug 11, 2019 9:09 pm
Can anyone help me with Harry Potter and the Sorcerer's Stone? I have three different MPLS listed form Netflix DVD USA. Does anyone know the correct one?
Option 1:
Title information
Name: Harry Potter and the Sorcerer's Stone
Source file name: 00102.mpls
Duration: 2:32:21
Chapters count: 40
Segment count: 10
Segment map: 205,206,207,208,220,221,209,210,211,906
File name: Harry Potter and the Sorcerer's Stone_t01.mkv
Option 2:
Title information
Source file name: 00101.mpls
Duration: 2:38:50
Chapters count: 35
Segment count: 16
Segment map: 205,212,206,213,207,214,208,215,220,223,216,209,217,218,226,906
File name: Harry Potter and the Sorcerer's Stone_t02.mkv
Option 3:
Title information
Source file name: 00100.mpls
Duration: 2:32:21
Chapters count: 35
Segment count: 10
File name: Harry Potter and the Sorcerer's Stone_t03.mkv
Thank you..!
-Jason
Re: Harry Potter and the Sorcerer's Stone - Correct MPLS
Post by Woodstock » Sun Aug 11, 2019 10:06 pm
It really depends on which "cut" you want.
00100.mpls is probably the English theatrical cut. 102 changes out the opening titles and closing credits (probably for Spanish or French), and 101 has extra scenes (probably a "director's cut") added in.
preserve
Post by preserve » Sat Jan 02, 2021 8:00 am
100 is the theatrical cut.
101 is the extended cut.
102 is the theatrical cut along with an "In-Movie Experience" including video director commentary clips, still galleries, and storyboards *
* I haven't looked at it in much detail, but it seems that it's probably all controlled via Java, rather than a traditional audio commentary and perhaps using a subtitle track for pop-up images, so you won't see the bonus material if you rip this to an MKV.
Originally released as the "Harry Potter 1 Ultimate Edition" in 2009 after the film's initial Blu-ray release in 2007, this disc was later included in the "Complete 8-Film Collection" as well as the "Two-Disc Special Edition" releases. The same MPLS numbering also applies to the Canadian "Harry Potter and the Philosopher's Stone" versions of this release.
Using MakeMKV 1.15.4, the seamless branching on this disc does have AV Sync issues with its primary DTS-HD MA Surround 5.1 English audio:
100:
AV synchronization issues were found in file 'E:/Video/Harry Potter 1/Harry Potter and the Philosopher's Stone_t07_s00100.mkv' (title #8)
AV sync issue in stream 1 at 0:08:40.394 with duration of 10.458ms : encountered overlapping frame, audio skew is +10.458ms
AV sync issue in stream 1 at 0:10:19.243 with duration of 9.916ms : encountered overlapping frame, audio skew is +20.375ms
AV sync issue in stream 1 at 0:10:19.264 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +9.708ms
AV sync issue in stream 1 at 0:18:28.315 with duration of 5.416ms : encountered overlapping frame, audio skew is +15.125ms
AV sync issue in stream 1 at 0:18:28.330 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +4.458ms
AV sync issue in stream 1 at 0:53:18.403 with duration of 2.666ms : encountered overlapping frame, audio skew is +7.125ms
AV sync issue in stream 1 at 1:12:47.363 with duration of 0.541ms : encountered overlapping frame, audio skew is +7.666ms
AV sync issue in stream 1 at 1:13:48.882 with duration of 5.541ms : encountered overlapping frame, audio skew is +13.208ms
AV sync issue in stream 1 at 1:13:48.896 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.541ms
AV sync issue in stream 1 at 1:34:43.469 with duration of 5.333ms : encountered overlapping frame, audio skew is +7.875ms
AV sync issue in stream 1 at 1:37:33.222 with duration of 7.083ms : encountered overlapping frame, audio skew is +14.958ms
AV sync issue in stream 1 at 1:37:33.237 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +4.291ms
AV sync issue in stream 1 at 1:38:39.121 with duration of 10.166ms : encountered overlapping frame, audio skew is +14.458ms
AV sync issue in stream 1 at 1:38:39.136 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +3.791ms
101:
AV synchronization issues were found in file 'E:/Video/Harry Potter 1/Harry Potter and the Philosopher's Stone_t06_s00101.mkv' (title #7)
AV sync issue in stream 1 at 0:09:31.320 with duration of 7.458ms : encountered overlapping frame, audio skew is +17.916ms
AV sync issue in stream 1 at 0:09:31.338 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +7.25ms
AV sync issue in stream 1 at 0:11:10.169 with duration of 9.916ms : encountered overlapping frame, audio skew is +17.166ms
AV sync issue in stream 1 at 0:11:10.186 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +6.5ms
AV sync issue in stream 1 at 0:11:43.244 with duration of 2.625ms : encountered overlapping frame, audio skew is +9.125ms
AV sync issue in stream 1 at 0:19:52.316 with duration of 5.416ms : encountered overlapping frame, audio skew is +14.541ms
AV sync issue in stream 1 at 0:19:52.330 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +3.875ms
AV sync issue in stream 1 at 0:20:26.975 with duration of 7.041ms : encountered overlapping frame, audio skew is +10.916ms
AV sync issue in stream 1 at 0:20:26.986 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.25ms
AV sync issue in stream 1 at 0:55:17.063 with duration of 2.666ms : encountered overlapping frame, audio skew is +2.916ms
AV sync issue in stream 1 at 0:56:43.483 with duration of 1.666ms : encountered overlapping frame, audio skew is +4.583ms
AV sync issue in stream 1 at 1:16:12.442 with duration of 0.541ms : encountered overlapping frame, audio skew is +5.125ms
AV sync issue in stream 1 at 1:17:30.270 with duration of 6.916ms : encountered overlapping frame, audio skew is +12.041ms
AV sync issue in stream 1 at 1:17:30.282 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.375ms
AV sync issue in stream 1 at 1:38:24.857 with duration of 5.333ms : encountered overlapping frame, audio skew is +6.708ms
AV sync issue in stream 1 at 1:42:08.455 with duration of 6.958ms : encountered overlapping frame, audio skew is +13.666ms
AV sync issue in stream 1 at 1:42:08.469 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +3ms
AV sync issue in stream 1 at 1:45:08.343 with duration of 5.291ms : encountered overlapping frame, audio skew is +8.291ms
Using: ASUS BW-16D1HT 3.00
