50% success rate
phytonic13
50% success rate
Post by phytonic13 » Fri Jan 01, 2021 8:17 pm
Hi. I've been having about a 50% success rate ripping 4k discs. A lot of times I have to restart the computer or figure out the correct sequence of loading and launching the program just to get the disc to read. My drive is the lg bu40n. Is this typical as of now with 4k discs or is there a more reliable drive? Thank you.
jonghotti
Re: 50% success rate
Post by jonghotti » Fri Jan 01, 2021 11:13 pm
There is a bit of a learning curve when adding 4K discs to the mix and I'm sorry you're having trouble. Cleaning each disc with LCD screen cleaner and a microfiber cloth should greatly increase your success stats there. Please email or text me if you need specific instructions on cleaning although I believe I've posted them several times. Thank you!
