2001 A Space Odyssey Video can't be decrypted
RScottyL
Post by RScottyL »
So, I just received my LG WH14NS40 and successfully flashed it to WH16NS60!
I am trying to test rip a 4K UHD disc and get a message that the video cannot be decrypted, although I thought it was supposed to access the disc directly and not have to do that!
Here are my details on MakeMKV 1.15.2:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLZK56B5959
Highest AACS version: 66
Firmware version: 1.02
Disc Information
Label: 2001_ A Space Odyssey
Timestamp: 2018-11-01 13:37:34
Data capacity: 80.29 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Using LibreDrive mode (v06.2 id=7FA2657C7667)
Downloading latest HK to C:\Users\Scott Luther/.MakeMKV ...
Saved AACS dump file as C:\Users\Scott Luther/.MakeMKV/MKB20_v66_2001-_A_Space_Odyssey_ADDF.tgz
Any ideas?
Re: 2001 A Space Odyssey Video can't be decrypted
Send that file to svq@makemkv.com for analysis, and it should work in a few days.
RScottyL
Post by RScottyL »
Woodstock wrote: Wed Aug 19, 2020 5:24 pm
I tried another and came up with the same thing.
I assume send in the dump files for any I come across?
aloha
Post by aloha »
Hello:
Maybe this is part of the problem?
Regards,
A
greatestguru
Post by greatestguru »
RScottyL wrote: Wed Aug 19, 2020 4:39 pm So, I just received my LG WH14NS40 and successfully flashed it to WH16NS60!
Revision: 1.02
Disc Information
Number of layers: 3
Any ideas?
Hey, I had the same issue earlier. I'm not sure if it will work for you but my Malwarebytes was blocking MakeMKV from downloading the necessary files to decrypt. I'd halt any security application in the background and make sure you're on the latest MakeMKV then start a RIP.
RScottyL
Post by RScottyL »
greatestguru wrote: Thu Aug 20, 2020 10:52 am Hey, I had the same issue earlier. I'm not sure if it will work for you but my Malwarebytes was blocking MakeMKV from downloading the necessary files to decrypt. I'd halt any security application in the background and make sure you're on the latest MakeMKV then start a RIP.
Good catch and that was the problem!
I have an Ubiquity UDM Pro and it has the Threat Management where you can block countries that are trying to hack you!
I had about 5 countries blocked at the time and unblocked them and that worked!
I just need to go back through and figure out which country MakeMKV tries to download from and make sure not to block that one!
greatestguru
Happy to help!!!
frost
Post by frost »
Did you ever get this disc working? I am attempting to rip the exact same one (2001: A Space Oddyssey 4K UHD), and MakeMKV is unable to decrypt for me as well. I have sent the dump to svq@makemkv.com.
The only difference I see is that I'm running the 1.05 patched firmware instead of 1.02.
OS device name: /dev/rdisk2
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KLQJ8Q82246
Firmware version: 1.05
Disc Information
Number of layers: 3
LemFra
Post by LemFra »
I have the same problem with this UDH-Video.
I have ripped another UDH two weeks ago, and I had no problems.
What am I doing that is wrong, now ?
Informations lecteur
Nom du lecteur SE : /dev/rdisk4
Profil actuel : BD-ROM
Fabricant : HL-DT-ST. (LG)
Produit : BD-RE WH16NS60
Révision : 1.02
Numéro de série : KLZK9NG1445
Date micrologiciel : 2118-10-29 19:36
Marqueurs d'encryptage bus : 17
Version AACS la plus haute : 66.
Information du disque
Titre: 2001_ A Space Odyssey. (Bar Code: 8 83929 63845 1)
Horodatage: 2018-11-01 13:37:34
Capacité de données : 80.29 Gb
Type de disque : BD-ROM UHD
Nombre de couches : 3
Marqueurs d'encryptage bus : 80
Protection: AACS2.0/C v66
MakeMKV v1.16.3
After 17 minutes: here are lines in <MakeMKV_log.txt>
Enregistrement de 4 titres dans le répertoire /Users/francoislemieux/Desktop/2001 - A space Odysey
Problèmes de synchronisation AV rencontrés dans le fichier '/Users/francoislemieux/Desktop/2001 - A space Odysey/title_t01.mkv' (titre #2)
Problème de synchro AV dans le flux 1 à 0:00:00 : 0 image(s) abandonnée(s) pour réduire le biais audo de +18ms
Problème de synchro AV dans le flux 1 à 0:00:00 d'une durée de 18ms : chevauchement d'images trouvé, le biais audio est de +18ms
Le fichier source '/BDMV/STREAM/00058.m2ts' est corrompu ou invalide en offset 24004564992, tentative de contournement
Le fichier source '/BDMV/STREAM/00058.m2ts' est corrompu ou invalide en offset 24004933632, tentative de contournement
Le fichier source '/BDMV/STREAM/00058.m2ts' est corrompu ou invalide en offset 24004945920, tentative de contournement
Le fichier source '/BDMV/STREAM/00058.m2ts' est corrompu ou invalide en offset 24004958208, tentative de contournement
Le fichier source '/BDMV/STREAM/00058.m2ts' est corrompu ou invalide en offset 24004970496-24004976640, tentative de contournement
Le fichier source '/BDMV/STREAM/00058.m2ts' est corrompu ou invalide en offset 24004988928, tentative de contournement
DEBUG: Code 69890 at [0VX^I!l,wDb%h7x[!wg:29395563
Le fichier source '/BDMV/STREAM/00058.m2ts' est corrompu ou invalide en offset 24010395648, tentative de contournement
DEBUG: Code 2 at [0VX^I!l,wDb%h7x[!wg:121263475
Le fichier source '/BDMV/STREAM/00058.m2ts' est corrompu ou invalide en offset 24012294144, tentative de contournement
etc, etc…
Regards
Disk read errors are not decryption issues. Fixing why the disk isn't readable will probably allow it to be ripped without issue.
Check out the "read here first" message at the top of the Bluray forum; it applies to UHD, too.
