Creating a MKV file from the UHD Copy
shivac77
I was looking for an option to create the MKV file from the UHD dump/Copy. It was loading the file as directory and goes to the base file levels instead of recognizing it as a disk or folder to use as the source. But DVDFAB is able to load the dump folder as a disk and able to extract to MKV with required details. I may be missing on this tool but not sure how to do this. If you have come across this, your insight is greatly appreciated !!
Re: Creating a MKV file from the UHD Copy
Are you meaning from an MakeMKV backup, or from a UHD ISO file?
shivac77
It's MakeMKV Backup. Let me put this way. Successfully made a copy of the UHD with all its content. From this dump, if I want to make an MKV file, I am unable to do it.
You did the backup with MakeMKV? If yes, you should be able to open it with MakeMKV. If no, then you are missing vital information from the disc.
shivac77
Yes I did backup(Copy) with MakeMKV. But I can't open the m2ts file through MKV or it can load as disc in the MKV.
It's not with one and same with all. Not sure what's missing here
shivac77
Yes, it was with MakeMKV as a copy. The challenge is I can't load the copied folder or M2TS file with makeMkv to make an MKV file.
In MakeMKV, click on Files, Open Files. A window will open up that will allow you to browse for files.
Navigate to where the backup was created. Find the directory for the backup you made. In it, you will find a directory named BDMV. In that directory, you will find a file named index.bdmv. Select it, and click Open.
When it finishes reading the information, you can select which titles you want to convert to MKV files, just as if you had opened the disk directly.
shivac77
Thank you so much. You nailed it down.
baidun
I'm new to this forum but have been readin in order to be able to make backup copies of my UHD discs with the intent of using Plex to watch the movies.
I purchased an Archon UHD player and downgraded the firmware to v1.00 per what I read on this forum. Running MakeMKV shows the LibreDrive is active and MakeMKV was able to create a backup of the UHD movie. It created a whole folder structure with a bunch of M2TS files in the STREAM directory.
Now I'd like to make an MKV file. I launched MakeMKV and selected 'open files' and pointed it to the discatt.dat file. It reads the file, identifies the movie, and ends with an error stating 'The volume key is unknown for this disc - video can't be decrypted, failed to open disc'
Can anyone assist with what I may have done wrong?
Nope, you obviously didn't read it properly. Also, you haven't decrypted the disc.baidun wrote: Thu Dec 31, 2020 1:03 am Hi,
When backing up to folder, make sure the "decrypt" checkbox is checked. MakeMKV will then decrypt the entire disc into a folder. Then you select either the index.bdmv or MovieObject.bdmv file and MakeMKV will open the backup folder so you can create a MKV file.
preserve
From the stickied UHD FAQ:baidun wrote: Thu Dec 31, 2020 1:03 am'The volume key is unknown for this disc - video can't be decrypted, failed to open disc'
Usually within a few days after you submit the dump, the key will be processed. Make sure that you have "Enable Internet access" enabled in Preferences (in the General tab), so that MakeMKV will check for updated keys when you try to open the disc again.preserve wrote: Thu Dec 21, 2017 3:42 amMakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
Using: ASUS BW-16D1HT 3.00
