The Lord of the Rings V.E 4K Dolby Vision HDR10 .m2ts join
Roberespa
Post by Roberespa »
“The Lord of the Rings” V.E 4K Dolby Vision HDR10 .m2ts
I have Disc 1 and Disc 2 in m2ts with Dolby Vision when I combine them with tsMuxeR, when Disc 2 (which is connected to Disc 1 + Disc 2) starts up the video audio is out of sync.
I open the "add" rings of tsMuxeR.
Then I click "join", add rings2, select M2TS, and start muxing.
As a result, when the second disc should start, the video gets out of sync with the audio.
Please help.
I think the problem lies in the interval between disk 1 and disk 2 during those 3-4 seconds of black screen.
Any ideas? Can anybody help me.
I think it is an interesting topic since many of us cannot join disk 1 with disk 2, using tsMuxeR.
Re: The Lord of the Rings V.E 4K Dolby Vision HDR10 .m2ts join
I think the solution is like Marty said the other day in another similar topic don't join them together
Roberespa
Post by Roberespa »
There is no way to tell the tsMuxeR program to cut the video before the screen goes black.
Video summary set to end 01: 45: 47: 000
This way without the black screen between disc 1 and 2 it may not desynchronize audio with video.
ChrisI
Post by ChrisI »
I don't own the 4K, but had a similar issue when ripping the EE BR.
I used MKVToolNix GUI to trim the ends after ripping, and then appending the trimmed pieces in a second pass.
