Confirming Compatibility
hilde
Re: Confirming Compatibility
Post by hilde » Fri Apr 03, 2020 3:21 pm
I deciced that I couldn't wait and replaced the old drive with an ASUS.
When taking a look at the label I noticed it is even more ancient than I thought,
looks like I cross flashed it from WS10LS30 already and then forgot about it :-D
CoBrA2168
Post by CoBrA2168 » Wed Dec 30, 2020 11:01 pm
Sorry to bring back an older topic back from the dead, but I was wondering if LibreDrive support was ever added to the LG WH12LS39 model drive. I have this very drive (v1.03 firmware) and it works fine with MakeMKV. I'm unsure if I even need LD support for this drive since it isn't 4k...
Thanks in advance.
Post by Billycar11 » Wed Dec 30, 2020 11:47 pm
CoBrA2168 wrote: Wed Dec 30, 2020 11:01 pm Sorry to bring back an older topic back from the dead, but I was wondering if LibreDrive support was ever added to the LG WH12LS39 model drive. I have this very drive (v1.03 firmware) and it works fine with MakeMKV. I'm unsure if I even need LD support for this drive since it isn't 4k...
Thanks in advance.
Not sure best way is to look at your makemkv drive info that will tell you if it's enabled.
But it's not needed the only benefit on that drive would be no aacs getting revoked
CoBrA2168
Post by CoBrA2168 » Thu Dec 31, 2020 11:29 am
Billycar11 wrote: Wed Dec 30, 2020 11:47 pm
Thanks in advance.
I'll have to check later today, but I don't believe it said anything about it being enabled.
I was just wondering if compatibility was ever added for this drive, since it sounded like from the previous postings that it would eventually be added.
EDIT: Here's what MakeMKV says about this drive:
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.03-D0
Based on what mike said in the previous post, I figured maybe it would be added...soon?
