Vault
Post by Vault » Wed Dec 30, 2020 10:46 pm
shawnc22 wrote:
Wed Dec 23, 2020 9:16 am
MastaG wrote:
Wed Dec 23, 2020 9:12 am
So which players are capable of playing FEL remuxes from network sources (Plex/Emby/SMB), e.g. the full deal retaining the 12bit 4000nits final picture like when playing the original disc?
e.g. remuxed into a TS or MKV container so I can add a high def audio track?
From network? The oppo and that's it.
shawnc22 wrote:
Thu Dec 24, 2020 5:03 pm
When you’re doing conversions from a UHD disc to single layer, you’re going to lose data (neglible in MEL). There is currently not a lossless way from converting from double to single layer where the info in the EL is reencoded into the BL; any info in the EL is just being discarded.
Hi Shawnc22,
Like MastaG I was hoping for a 1:1 experience paradise, when I read a few weeks ago that MKV + DV was live.
But I understand (thanks to you + contributors) that YTD it remains a lossy process, even using 1.15.4.
I had in mind to convert the ISOs I have : MakeMKV + playback via Shield Pro (those 2 purchases on hold for now).
But it seems that those ISOs, through Oppo or Clone, are still the way to go if we want 1:1 DV + HD audio tracks ?
Or am I getting something wrong here ? Any light appreciated.
PS : reading below Reset_9999, seems the Shield's ignoring FEL. So that wraps it up... 2020. What a nightmare :mrgreen:
Post by shawnc22 » Thu Dec 31, 2020 5:03 am
Hi Shawnc22,
The conversion process used by makemkv 1.15.3+ is in itself a lossless conversion. The issue is that no current devices can play them (FEL titles) in their full capacity. The Oppo and its clones (iso/ts remux) or an x700 (ts remux) then are your only options for 1:1 playback.
lexyz
Post by lexyz » Thu Dec 31, 2020 5:25 am
But if you have a Sony Bravia TV with LLDV there is a dilemma :D :
- Play it on BR player or clone with artefacts and muted colors
- Play it on Shield TV Pro with richer but inaccurate colors (red push) and without EL
- Play it on any device as HDR10 version with proper colors.
I suggest Bravia owners like myself drop DV playback for UHD BR.
Bravias doesn't aggressively tonemap HDR and usually good in tracking PQ curve. So picture is quite close to creators intend for HDR version.
DV in streaming apps is a different story.
userr
Post by userr » Thu Dec 31, 2020 7:44 am
i dont understand what you mean with
even with bravia tv, playing a UHD with for example oppo in player-led, isnt the picture as good as for example LG (using player-led with oppo)
lexyz
Post by lexyz » Thu Dec 31, 2020 8:27 am
There is no reason to use player-led (LLDV) on LG
For Sony it is only option (except XH90)
userr
Post by userr » Thu Dec 31, 2020 10:58 am
i understand that.
what im saying is that, using player-led with an oppo for example, still makes use of dual-layer/single-layer-makemkv-files profile7, its just not "the best" as tv-led
Vault
Post by Vault » Thu Dec 31, 2020 11:38 am
Thank you for the precise feedback. Appreciated.
Hoping for a better option/MKV update in the future.
And btw : wishing everyone a great new year's eve :wink:
magnetoeric
Post by magnetoeric » Thu Dec 31, 2020 4:42 pm
Hi Shawnc22,
I'm planning to get x700. Do you know whether it can play DV with FEL in m2ts container? I have an old bdp s6700 which can play m2ts remuxes fine (although only 1080p).
bgalakazam
Post by bgalakazam » Thu Dec 31, 2020 10:26 pm
I have been watching DV with FEL on my X700 in m2ts/ts via a tsMuxer mux from a full bluray rip for a while now.
Sony X700 -> Onkyo TX-RZ830 -> LG C8
aboulfad
Post by aboulfad » Fri Jan 01, 2021 12:25 am
Out of curiosety, I ripped Aquaman and created an mkv with 1.15.4 (single track double layer?, MEL) and tried Aquaman on my "virgin" 203 (via USB), it came up as HDR10. Not sure if the Oppo requires a JB to play DV mkv or if that's supported at all.
deo
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Duration                                 : 2 h 23 min
Bit rate                                 : 54.8 Mb/s
Bits/(Pixel*Frame)                       : 0.276
Stream size                              : 54.9 GiB (87%)
Maximum Content Light Level              : 1506 cd/m2
Maximum Frame-Average Light Level        : 459 cd/m2
glc650
Post by glc650 » Fri Jan 01, 2021 2:40 am
It can but with a Fast Ethernet port and only 2.4 WiFI I think the X800M2 (has 5ghz WiFi) is a better option. I just got the X800M2 and my AP usually shows me connected at 300mbps which is 150+mbps in reality in my environment and after 6+ DV movies I've yet to see an issue. Also, keep in mind that the X700/800M2 uses DLNA instead of SMB/NFS.
glc650
Post by glc650 » Fri Jan 01, 2021 2:44 am
m2ts or BDMV folder for DV. The Oppo will most likely never support DV in MKV since that would require a firmware update and with Oppo being out of the BR industry...
aboulfad
Post by aboulfad » Fri Jan 01, 2021 3:46 am
Thx, I'll try that next: Movie name -> BDMV folder ? too bad Oppo's media browser is so outdated.
glc650
Post by glc650 » Fri Jan 01, 2021 4:04 am
movie name > AVCHD > BDMV
https://watershade.net/wmcclain/UDP-203 ... hd-backups
aboulfad
Post by aboulfad » Fri Jan 01, 2021 4:45 am
Thx for the link, for USB no AVCHD was required and I needed the other folders (cert) for the movie to play in its full dvhe.07.06 glory :D its an ok temporary solution as my DV collection is small.
