Jurassic World Fallen Kingdom Uncorrectable Error
BlitsNChitz
Post by BlitsNChitz »
About 3 minutes into ripping Jurassic World Fallen Kingdom the rip fails. I am trying to rip the UHD 4K version (I have successfully ripped the HD BD disc from the same disc/movie case). Below is the error log. I am running Make MKV v1.15.3 with WH16NS40 drive 1.02 firmware using libre drive mode.
I have tried multiple times to no luck, The error message isn't always the same, sometimes it comes up with *illegal action something, something* (I will run it again until I get that error log and post it as well).
This is the first movie I have had any trouble with.
Any help would be appreciated, Cheers!
Saving 1 titles into directory H:/MKV Rips Plex/Movies/4K UHD/Jurassic World Fallen Kingdom
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '1170210816'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1170210816'
Failed to save title 4 to file H:/MKV Rips Plex/Movies/4K UHD/Jurassic World Fallen Kingdom/Jurassic World- Fallen Kingdom_t04.mkv
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
preserve
Re: Jurassic World Fallen Kingdom Uncorrectable Error
Post by preserve »
The drive is having an issue reading data from the disc...
These links may offer relevant troubleshooting:
viewtopic.php?f=8&t=15055
Using: ASUS BW-16D1HT 3.00
sgtblackice
Post by sgtblackice »
Clean cloth or worst case a wipe with some isopropyl alcohol on a cloth and then a good buff is normally all that's needed to remove the factory dirt/grease layer that prevents UHD's reading.
I've had great success with nearly all discs using this approach. If the disc has damage then you'll likely need a replacement disc. UHD discs are incredibly sensitive to any marks on the read surface.
Best of luck
BlitsNChitz
This is the error with the illegal request.
This also happened after buffing the disc with some isopropyl alcohol and a glass cleaning cloth. The disc itself looks fine with no scratches and will play in my Xbox one x.
Error 'OS error - The end-of-file marker has been reached. There is no valid data in the file beyond this marker' occurred while reading '\Device\CdRom0' at offset '33131264000'
udf: node fe/efe failed!
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '1142224896'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '938182656'
