lexyz
Post by lexyz » Wed Dec 30, 2020 4:59 pm
userr
Shield plays p7 STDL (mkv or ts) BL and RPU (metadata). It is 100%
FEL is unclear. There is no test patterns to tell for sure.
Probaly new SM UHD Benchmark disk will have one. Will see in Q2'21
But after numerous viewings of "Shuttle scene" in Total Recall I tend to belive Shield just skip FEL and plays BL+RPU only. At least in LLDV mode.
This scene has extremely poorly encoded HDR10 layer and all film grain remains in FEL. So difference BL vs BL+FEL is noticeable.
Post by RESET_9999 » Wed Dec 30, 2020 5:05 pm
yep, I'm pretty sure the Shield is ignoring the FEL. Even Nvidia said it only supports MEL.
plus the colors are totally wrong and oversaturated with red spots everywhere. (MEl or FEl or RPU p8)
For UHD-BD rip, HDR10 is better than Dolby Vision on the Shield.
https://screenshotcomparison.com/comparison/9580
aboulfad
Post by aboulfad » Wed Dec 30, 2020 6:17 pm
... For UHD-BD rip, HDR10 is better than Dolby Vision on the Shield.
Interesting, I am reaching a similar conclusion for my unrelated limited trials with DV P5 (InfusePro) for ATV4K using yusesope’s mode 2 (which he warned to stay away from but no other choice for ATV4K).
I have ripped 2 DV UHD and tried to compare the ATV+ (iTunes) DV with the mode 2 and HDR10 of the same scenes. It is hard to do a fair comparison as switching between the various apps is slow and my LG TV doesn’t allow screenshots for DV vision.
In terms of my perceived subjective PQ (pic quality):
1- ATV+ iTunes DV - best
2- BD rip -> mkv which plays in HDR10 thru InfusePro - good
3- DV P5 (mode 2) - just ok
Roberespa
Post by Roberespa » Wed Dec 30, 2020 9:12 pm
RESET_9999 wrote:
Tue Dec 29, 2020 11:10 pm
Roberespa wrote:
Tue Dec 29, 2020 9:08 pm
Updated program tsMuxeR 2020-12-29 Nightly (x64)
I have done it again as you indicated. I took the .mpls from disk 1 and disk 2 and created a m2ts.
Again there is desynchronization
of the audio with the video just when disc two would enter, as I mentioned.
I dont know. The 3 movies are perfectly in sync on my end. both the x700 and on my pc. what media player do you use ?
I did the extended version if that make a difference. Also, i did it a couple weeks ago, so not really the latest tsmuxer version.. Maybe a bug introduced in the latest version?
Complete name                            : D:\The.Lord.of.the.Rings.1.The.Fellowship.of.the.Ring.2001.DV.ts
File size                                : 122 GiB
Duration                                 : 3 h 48 min
Overall bit rate                         : 76.6 Mb/s
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Maximum Content Light Level              : 602 cd/m2
Maximum Frame-Average Light Level        : 184 cd/m2
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : 6
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Audio #1
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 4 992 kb/s
Stream size                              : 732 MiB (1%)
VLC media player
I tried with the Blu-ray version and the tsMuxeR got the same error.
MKVToolNix GUI
Assembles it without problems. But I need to do it with tsMuxer to get Dolby Vision in .m2ts
Roberespa
Post by Roberespa » Wed Dec 30, 2020 9:15 pm
I don't know if maybe the problem lies in the 3-4 seconds that the film turns black
While going to what would be disc 2.
Vault
Post by Vault » Wed Dec 30, 2020 10:46 pm
shawnc22 wrote:
Wed Dec 23, 2020 9:16 am
MastaG wrote:
Wed Dec 23, 2020 9:12 am
So which players are capable of playing FEL remuxes from network sources (Plex/Emby/SMB), e.g. the full deal retaining the 12bit 4000nits final picture like when playing the original disc?
e.g. remuxed into a TS or MKV container so I can add a high def audio track?
From network? The oppo and that's it.
shawnc22 wrote:
Thu Dec 24, 2020 5:03 pm
When you’re doing conversions from a UHD disc to single layer, you’re going to lose data (neglible in MEL). There is currently not a lossless way from converting from double to single layer where the info in the EL is reencoded into the BL; any info in the EL is just being discarded.
Hi Shawnc22,
Like MastaG I was hoping for a 1:1 experience paradise, when I read a few weeks ago that MKV + DV was live.
But I understand (thanks to you + contributors) that YTD it remains a lossy process, even using 1.15.4.
I had in mind to convert the ISOs I have : MakeMKV + playback via Shield Pro (those 2 purchases on hold for now).
But it seems that those ISOs, through Oppo or Clone, are still the way to go if we want 1:1 DV + HD audio tracks ?
Or am I getting something wrong here ? Any light appreciated.
PS : reading below Reset_9999, seems the Shield's ignoring FEL. So that wraps it up... 2020. What a nightmare :mrgreen:
Post by shawnc22 » Thu Dec 31, 2020 5:03 am
Hi Shawnc22,
The conversion process used by makemkv 1.15.3+ is in itself a lossless conversion. The issue is that no current devices can play them (FEL titles) in their full capacity. The Oppo and its clones (iso/ts remux) or an x700 (ts remux) then are your only options for 1:1 playback.
lexyz
Post by lexyz » Thu Dec 31, 2020 5:25 am
But if you have a Sony Bravia TV with LLDV there is a dilemma :D :
- Play it on BR player or clone with artefacts and muted colors
- Play it on Shield TV Pro with richer but inaccurate colors (red push) and without EL
- Play it on any device as HDR10 version with proper colors.
I suggest Bravia owners like myself drop DV playback for UHD BR.
Bravias doesn't aggressively tonemap HDR and usually good in tracking PQ curve. So picture is quite close to creators intend for HDR version.
DV in streaming apps is a different story.
userr
Post by userr » Thu Dec 31, 2020 7:44 am
i dont understand what you mean with
even with bravia tv, playing a UHD with for example oppo in player-led, isnt the picture as good as for example LG (using player-led with oppo)
lexyz
Post by lexyz » Thu Dec 31, 2020 8:27 am
There is no reason to use player-led (LLDV) on LG
For Sony it is only option (except XH90)
userr
Post by userr » Thu Dec 31, 2020 10:58 am
i understand that.
what im saying is that, using player-led with an oppo for example, still makes use of dual-layer/single-layer-makemkv-files profile7, its just not "the best" as tv-led
Vault
Post by Vault » Thu Dec 31, 2020 11:38 am
Thank you for the precise feedback. Appreciated.
Hoping for a better option/MKV update in the future.
And btw : wishing everyone a great new year's eve :wink:
magnetoeric
Post by magnetoeric » Thu Dec 31, 2020 4:42 pm
Hi Shawnc22,
I'm planning to get x700. Do you know whether it can play DV with FEL in m2ts container? I have an old bdp s6700 which can play m2ts remuxes fine (although only 1080p).
bgalakazam
Post by bgalakazam » Thu Dec 31, 2020 10:26 pm
I have been watching DV with FEL on my X700 in m2ts/ts via a tsMuxer mux from a full bluray rip for a while now.
Sony X700 -> Onkyo TX-RZ830 -> LG C8
aboulfad
Post by aboulfad » Fri Jan 01, 2021 12:25 am
Out of curiosety, I ripped Aquaman and created an mkv with 1.15.4 (single track double layer?, MEL) and tried Aquaman on my "virgin" 203 (via USB), it came up as HDR10. Not sure if the Oppo requires a JB to play DV mkv or if that's supported at all.
deo
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Duration                                 : 2 h 23 min
Bit rate                                 : 54.8 Mb/s
Bits/(Pixel*Frame)                       : 0.276
Stream size                              : 54.9 GiB (87%)
Maximum Content Light Level              : 1506 cd/m2
Maximum Frame-Average Light Level        : 459 cd/m2
