#4036 Post by MartyMcNuts » Tue Dec 29, 2020 10:38 pm
Roberespa wrote:
Tue Dec 29, 2020 9:08 pm
RESET_9999 wrote:
Tue Dec 29, 2020 6:00 pm
Roberespa wrote:
Tue Dec 29, 2020 5:42 pm
Can you explain how you did it?
I have Disc 1 and Disc 2 in m2ts with Dolby Vision when I combine them with tsMuxeR, when Disc 2 (which is connected to Disc 1 + Disc 2) starts up the video audio is out of sync.
I open the "add" rings of tsMuxeR.
Then I click "join", add rings2, select M2TS, and start muxing.
As a result, when the second disc should start, the video gets out of sync with the audio.
Please help.
I always use the .mpls file(playlist folder) instead of the m2ts file so that might be the reason why.
Also, make sure that you use the latest nightly tsMuxer and not the old tsmuxer
https://bintray.com/justdan96/tsMuxer/t ... htly#files
Updated program tsMuxeR 2020-12-29 Nightly (x64)
I have done it again as you indicated. I took the .mpls from disk 1 and disk 2 and created a m2ts.
Again there is desynchronization
of the audio with the video just when disc two would enter, as I mentioned.
Don't join the movies together. Keep them separate.
#4037 Post by RESET_9999 » Tue Dec 29, 2020 11:10 pm
I dont know. The 3 movies are perfectly in sync on my end. both the x700 and on my pc. what media player do you use ?
I did the extended version if that make a difference. Also, i did it a couple weeks ago, so not really the latest tsmuxer version.. Maybe a bug introduced in the latest version?
Complete name                            : D:\The.Lord.of.the.Rings.1.The.Fellowship.of.the.Ring.2001.DV.ts
File size                                : 122 GiB
Duration                                 : 3 h 48 min
Overall bit rate                         : 76.6 Mb/s
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Maximum Content Light Level              : 602 cd/m2
Maximum Frame-Average Light Level        : 184 cd/m2
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : 6
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Audio #1
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 4 992 kb/s
Stream size                              : 732 MiB (1%)
pete19
Re:
#4038 Post by pete19 » Wed Dec 30, 2020 1:02 am
RESET_9999 wrote:
Tue Dec 29, 2020 7:00 pm
lexyz wrote:
Mon Dec 28, 2020 9:42 pm
Can you force P-led on X700+LG through Vertex thing?
If so you shouldn't rely on my pictures at all and can see difference by your own eyes
So after my latest reply, I decided to give another go to my Vertex. and btw I'm not relying on your picture at all.. I'm just saying that your comparisons with vincent's video means nothing and that you shouldn't rely on it
The firmware was a bit old so I updated it and now forcing lldv works.
I used content(p5 full range DV) that the Shield can actually play properly (not a uhd-bd rip so no red push affecting the output). On my LG C8, I don't really see any difference between the X700 p-led and the Shield p-led.
screenshot comparison: https://screenshotcomparison.com/comparison/9541
you need to use p7 with FEL in order to see differences - because the "problem" occurs when the EL is merged with the BL, and in LLDV this is done by the player/source and it won't be as accurate as tv-led
p5 does not have EL
Re: Re:
#4039 Post by RESET_9999 » Wed Dec 30, 2020 1:22 am
p5 does not have EL
Ok,
but the Shield is not capable of displaying p7 properly (or any other format than p5), so that comparison between the Shield and the x700 cannot be done (well it wouldn't mean anything).
Also, are you saying that MEL would look identical in player-led and tv-led ?
Re: Re:
#4040 Post by Manixx2020beyound » Wed Dec 30, 2020 2:35 am
p5 does not have EL
Ok,
U would have to do x700 fel LLDV vs x700 fel rgb dv8 to see if that’s true.
lexyz
#4041 Post by lexyz » Wed Dec 30, 2020 4:58 am
Regarding LLDV and Blu-Ray players
It seems all of them had identical Dolby SDK and provide same results
p7 FEL and p8 version show same artefacts and muted colors on LLDV X700+XF90
So FEL is not a cause. Could be metadata processing
Meanwhile Shield LLDV demonstrates noticable better picture - less artefacts, brighter colors.
Newer Dolby SDK?
Pictures https://slow.pics/c/SHnEtyql
Things to looks at - noise on the sky, muted colors of red flower and yellow beak
Also, if Dolby processing rely on closed SDK, which can be a black box for device manufacturer, it seems there is very little hope the "red push" will be ever fixed on Shield TV.
cipher
#4042 Post by cipher » Wed Dec 30, 2020 5:23 am
shawnc22 wrote:
Sat Dec 26, 2020 5:16 am
cipher wrote:
Sat Dec 26, 2020 5:06 am
Also, I found the following quotes on the nVidia forums:
The Shield supports both and will do TV-led if your TV supports it...
It does TV-led for me and I still get the slight red push.
Hi I didn’t think the Shield was doing TV-led with my C9 but it actually is, shame they can’t nail this on shield...
Therefore, assuming my LG B7 is capable of TV-led DV and the Shield can detect this and send the DV for the TV to process, is TV-led DV the result when using a Plex client that plays DV on the Shield? I'm currently switching between the native Plex client and the Kodi plex client on my Shield and want to make sure I'm aware of any differences here when playing DV mkv's.
Yes, it should be using TV-led DV on your B7
Thank you. For testing purposes, can one force a switch between TV-led and Player-led DV on the Shield?
#4043 Post by shawnc22 » Wed Dec 30, 2020 6:11 am
Only if you have a device to spoof edid like an hdfury.
pete19
Re: Re:
#4044 Post by pete19 » Wed Dec 30, 2020 9:29 am
no, not necessarily, but with FEL the differences will be more obvious when testing.
How easy it is to spot these differences also depends on the content.
userr
#4045 Post by userr » Wed Dec 30, 2020 4:43 pm
there is some speculation that profile 7 MKVs arent really played in DV with the 2019 shield, the TV gets a DV signal but what is shown is maybe HDR10 only, have there been comparisons made to debunk this speculation?
lexyz
#4046 Post by lexyz » Wed Dec 30, 2020 4:59 pm
userr
Shield plays p7 STDL (mkv or ts) BL and RPU (metadata). It is 100%
FEL is unclear. There is no test patterns to tell for sure.
Probaly new SM UHD Benchmark disk will have one. Will see in Q2'21
But after numerous viewings of "Shuttle scene" in Total Recall I tend to belive Shield just skip FEL and plays BL+RPU only. At least in LLDV mode.
This scene has extremely poorly encoded HDR10 layer and all film grain remains in FEL. So difference BL vs BL+FEL is noticeable.
#4047 Post by RESET_9999 » Wed Dec 30, 2020 5:05 pm
yep, I'm pretty sure the Shield is ignoring the FEL. Even Nvidia said it only supports MEL.
plus the colors are totally wrong and oversaturated with red spots everywhere. (MEl or FEl or RPU p8)
For UHD-BD rip, HDR10 is better than Dolby Vision on the Shield.
https://screenshotcomparison.com/comparison/9580
aboulfad
#4048 Post by aboulfad » Wed Dec 30, 2020 6:17 pm
... For UHD-BD rip, HDR10 is better than Dolby Vision on the Shield.
Interesting, I am reaching a similar conclusion for my unrelated limited trials with DV P5 (InfusePro) for ATV4K using yusesope’s mode 2 (which he warned to stay away from but no other choice for ATV4K).
I have ripped 2 DV UHD and tried to compare the ATV+ (iTunes) DV with the mode 2 and HDR10 of the same scenes. It is hard to do a fair comparison as switching between the various apps is slow and my LG TV doesn’t allow screenshots for DV vision.
In terms of my perceived subjective PQ (pic quality):
1- ATV+ iTunes DV - best
2- BD rip -> mkv which plays in HDR10 thru InfusePro - good
3- DV P5 (mode 2) - just ok
Roberespa
#4049 Post by Roberespa » Wed Dec 30, 2020 9:12 pm
File size                                : 122 GiB
Video #1
Video #2
Codec ID                                 : 6
Audio #1
Codec ID                                 : 131
VLC media player
I tried with the Blu-ray version and the tsMuxeR got the same error.
MKVToolNix GUI
Assembles it without problems. But I need to do it with tsMuxer to get Dolby Vision in .m2ts
Roberespa
#4050 Post by Roberespa » Wed Dec 30, 2020 9:15 pm
I don't know if maybe the problem lies in the 3-4 seconds that the film turns black
While going to what would be disc 2.
