Jurassic World Fallen Kingdom Uncorrectable Error
BlitsNChitz
#1 Post by BlitsNChitz » Wed Dec 30, 2020 2:38 pm
About 3 minutes into ripping Jurassic World Fallen Kingdom the rip fails. I am trying to rip the UHD 4K version (I have successfully ripped the HD BD disc from the same disc/movie case). Below is the error log. I am running Make MKV v1.15.3 with WH16NS40 drive 1.02 firmware using libre drive mode.
I have tried multiple times to no luck, The error message isn't always the same, sometimes it comes up with *illegal action something, something* (I will run it again until I get that error log and post it as well).
This is the first movie I have had any trouble with.
Any help would be appreciated, Cheers!
Saving 1 titles into directory H:/MKV Rips Plex/Movies/4K UHD/Jurassic World Fallen Kingdom
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '1170210816'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1170210816'
Failed to save title 4 to file H:/MKV Rips Plex/Movies/4K UHD/Jurassic World Fallen Kingdom/Jurassic World- Fallen Kingdom_t04.mkv
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
preserve
Re: Jurassic World Fallen Kingdom Uncorrectable Error
#2 Post by preserve » Wed Dec 30, 2020 3:39 pm
The drive is having an issue reading data from the disc...
These links may offer relevant troubleshooting:
viewtopic.php?f=8&t=15055
Using: ASUS BW-16D1HT 3.00
sgtblackice
#3 Post by sgtblackice » Wed Dec 30, 2020 4:06 pm
Clean cloth or worst case a wipe with some isopropyl alcohol on a cloth and then a good buff is normally all that's needed to remove the factory dirt/grease layer that prevents UHD's reading.
I've had great success with nearly all discs using this approach. If the disc has damage then you'll likely need a replacement disc. UHD discs are incredibly sensitive to any marks on the read surface.
Best of luck
BlitsNChitz
#4 Post by BlitsNChitz » Thu Dec 31, 2020 6:39 am
This is the error with the illegal request.
This also happened after buffing the disc with some isopropyl alcohol and a glass cleaning cloth. The disc itself looks fine with no scratches and will play in my Xbox one x.
Error 'OS error - The end-of-file marker has been reached. There is no valid data in the file beyond this marker' occurred while reading '\Device\CdRom0' at offset '33131264000'
udf: node fe/efe failed!
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '1142224896'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '938182656'
