bgalakazam
#4021 Post by bgalakazam » Mon Dec 28, 2020 10:59 pm
I still find the easiest, fastest, and least painful solution for Dolby Vision and lossless audio to be the X700 with a tsMuxer mix. If you have a newer model with eARC - kudos. And it plays UHD Blurays. I do give the shield gigabit ethernet and the MKV lossless TrueHD.
Sony X700 -> Onkyo TX-RZ830 -> LG C8
crashburn162
#4022 Post by crashburn162 » Tue Dec 29, 2020 2:41 pm
So I just downloaded Soul mixed in .mp4 with DV I can say it works fine without any hassle on LG Oled C9 with it's native player it turns on the DV and it's not a problem. The sound is lossy but since it's from a stream it's lossy non the less. Is there a way to do the loseless sound with DV if your TV has E-ARC ?
akelu
#4023 Post by akelu » Tue Dec 29, 2020 2:59 pm
Can you elaborate on this? Googling didnt really give me the answers. Thanks.
bgalakazam
#4024 Post by bgalakazam » Tue Dec 29, 2020 4:06 pm
akelu wrote: Tue Dec 29, 2020 2:59 pm Can you elaborate on this? Googling didnt really give me the answers. Thanks.
- Open a UHD Bluray rip's main playlist file in tsMuxer.
- Mux to .ts (or .m2ts).
- Play the file via a network share or USB from your Sony X700 or your LG OLED.
If you have an LG OLED <=2018 like me, no lossless audio will be passed back to receiver. So I use the X700 for those titles. Also the PGS subs will not work, just use a .SRT in same folder if you need subs.
#4025 Post by RESET_9999 » Tue Dec 29, 2020 4:25 pm
lexyz wrote: Mon Dec 28, 2020 9:42 pm Can you force P-led on X700+LG through Vertex thing?
If so you shouldn't rely on my pictures at all and can see difference by your own eyes
of course, if I could force lldv and see with my own eyes I would have posted a comparison a long time ago.
there's the LLDV Sony EDID option in my first gen Vertex but unfortunately, I'm not able to make it work. All I get is tv-led.
Roberespa wrote: Mon Dec 28, 2020 3:57 pm
But i do not know why
tsMuxeR desynchronizes the audio with the video. = (
TsMuxer does not desynchronize the audio/video. I merged the Lord of The Rings movies in a single file. I watched all of them without any sync issue.
Tsmuxer is actually my favorite tool to mux seamless branching movie because it properly removes overlapping frames.
Roberespa
#4026 Post by Roberespa » Tue Dec 29, 2020 5:42 pm
RESET_9999 wrote: Tue Dec 29, 2020 4:25 pm
Can you explain how you did it?
I have Disc 1 and Disc 2 in m2ts with Dolby Vision when I combine them with tsMuxeR, when Disc 2 (which is connected to Disc 1 + Disc 2) starts up the video audio is out of sync.
I open the "add" rings of tsMuxeR.
Then I click "join", add rings2, select M2TS, and start muxing.
As a result, when the second disc should start, the video gets out of sync with the audio.
Please help.
#4027 Post by RESET_9999 » Tue Dec 29, 2020 6:00 pm
Roberespa wrote: Tue Dec 29, 2020 5:42 pm
Please help.
I always use the .mpls file(playlist folder) instead of the m2ts file so that might be the reason why.
Also, make sure that you use the latest nightly tsMuxer and not the old tsmuxer
https://bintray.com/justdan96/tsMuxer/t ... htly#files
#4028 Post by RESET_9999 » Tue Dec 29, 2020 7:00 pm
So after my latest reply, I decided to give another go to my Vertex. and btw I'm not relying on your picture at all.. I'm just saying that your comparisons with vincent's video means nothing and that you shouldn't rely on it
The firmware was a bit old so I updated it and now forcing lldv works.
I used content(p5 full range DV) that the Shield can actually play properly (not a uhd-bd rip so no red push affecting the output). On my LG C8, I don't really see any difference between the X700 p-led and the Shield p-led.
screenshot comparison: https://screenshotcomparison.com/comparison/9541
blenky
#4029 Post by blenky » Tue Dec 29, 2020 7:12 pm
Been away from this thread for a few weeks so trying to catch up.
I understand that the latest MakeMKV (1.15.4) can now remux a MEL DV UHD Bluray.
For FEL a MEL needs to be created. Is the post below still the preferred method or has it been updated? Thanks
https://www.makemkv.com/forum/viewtopic ... 360#p97878
kazuma
#4030 Post by kazuma » Tue Dec 29, 2020 7:55 pm
can anybody upload a small DV-file of MKV? so we can test?
Re:
#4031 Post by Manixx2020beyound » Tue Dec 29, 2020 8:48 pm
RESET_9999 wrote: Tue Dec 29, 2020 7:00 pm
Can u do a Soul comparison with the real dv rgb dv-8bit? just for fun.
From both playback devices.
Curious too see on your calibrated c8 to see
If differences of dual tone mapping can be observed LLDV vs rgb 8 like Vincent showed.
Roberespa
#4032 Post by Roberespa » Tue Dec 29, 2020 9:08 pm
RESET_9999 wrote: Tue Dec 29, 2020 6:00 pm
Please help.
Updated program tsMuxeR 2020-12-29 Nightly (x64)
I have done it again as you indicated. I took the .mpls from disk 1 and disk 2 and created a m2ts.
Again there is desynchronization
of the audio with the video just when disc two would enter, as I mentioned.
#4033 Post by MartyMcNuts » Tue Dec 29, 2020 10:38 pm
Roberespa wrote: Tue Dec 29, 2020 9:08 pm
Please help.
Don't join the movies together. Keep them separate.
#4034 Post by RESET_9999 » Tue Dec 29, 2020 11:10 pm
I dont know. The 3 movies are perfectly in sync on my end. both the x700 and on my pc. what media player do you use ?
I did the extended version if that make a difference. Also, i did it a couple weeks ago, so not really the latest tsmuxer version.. Maybe a bug introduced in the latest version?
Complete name                            : D:\The.Lord.of.the.Rings.1.The.Fellowship.of.the.Ring.2001.DV.ts
File size                                : 122 GiB
Duration                                 : 3 h 48 min
Overall bit rate                         : 76.6 Mb/s
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Maximum Content Light Level              : 602 cd/m2
Maximum Frame-Average Light Level        : 184 cd/m2
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : 6
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Audio #1
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 4 992 kb/s
Stream size                              : 732 MiB (1%)
pete19
Re:
#4035 Post by pete19 » Wed Dec 30, 2020 1:02 am
you need to use p7 with FEL in order to see differences - because the "problem" occurs when the EL is merged with the BL, and in LLDV this is done by the player/source and it won't be as accurate as tv-led
p5 does not have EL
