Feature Request?
mhadi
Feature Request?
#1 Post by mhadi » Tue Dec 29, 2020 7:51 pm
First, forgive me if I've posted this in the wrong section. As I use MakeMKV on both OSX and Linux, I figured I'd just post here for both versions.
When I rip a Blu-Ray or UHD, I generally only pull the English audio and subtitles... which means I have to go through and unselect everything else. I don't need French, Chinese, Thai, Arabic, etc. In my experience, a lot of the time, there are 20+ languages. That's A LOT of unselecting, especially when I'm ripping a 100-episode/multi-disc tv show.
Unless I've missed something, there seems to be no way to "Unselect All", so that I can then go in and only select the 5 items I want.
Is there *any* way to get a "Select All/Unselect All" menu/menubar item added? I cannot believe I'm the only one who would benefit from having this.
Thanks,
Michael
Re: Feature Request?
#2 Post by Woodstock » Tue Dec 29, 2020 8:09 pm
Move mouse cursor into left side menu. "Right click" to open the Context menu. Click on Unselect all.
Ezatoka
#3 Post by Ezatoka » Tue Dec 29, 2020 11:16 pm
Why don't you change the default selection rule in the Advanced tab in the options? You might need to check "Expert mode" at the first page of the settings.
glamdring
#4 Post by glamdring » Wed Dec 30, 2020 3:19 am
If you set your language in the settings the query should select subtitles and audio tracks with your language or if you want multiple you can set a custom query that selects specific ones.
Figuring this out was a huge time saver for me, I was manually checking / unchecking so much stuff. :D
Here is a post with the query options: https://www.makemkv.com/forum/viewtopic.php?f=10&t=4386
mhadi
#5 Post by mhadi » Sat Jan 02, 2021 3:56 pm
Woodstock & glamdring: Thank you so much, both solutions works beautifully
