bgalakazam
I still find the easiest, fastest, and least painful solution for Dolby Vision and lossless audio to be the X700 with a tsMuxer mix. If you have a newer model with eARC - kudos. And it plays UHD Blurays. I do give the shield gigabit ethernet and the MKV lossless TrueHD.
Sony X700 -> Onkyo TX-RZ830 -> LG C8
crashburn162
So I just downloaded Soul mixed in .mp4 with DV I can say it works fine without any hassle on LG Oled C9 with it's native player it turns on the DV and it's not a problem. The sound is lossy but since it's from a stream it's lossy non the less. Is there a way to do the loseless sound with DV if your TV has E-ARC ?
akelu
Can you elaborate on this? Googling didnt really give me the answers. Thanks.I still find the easiest, fastest, and least painful solution for Dolby Vision and lossless audio to be the X700 with a tsMuxer mix. If you have a newer model with eARC - kudos. And it plays UHD Blurays.
bgalakazam
- Open a UHD Bluray rip's main playlist file in tsMuxer.akelu wrote: Tue Dec 29, 2020 2:59 pm Can you elaborate on this? Googling didnt really give me the answers. Thanks.
- Mux to .ts (or .m2ts).
- Play the file via a network share or USB from your Sony X700 or your LG OLED.
If you have an LG OLED <=2018 like me, no lossless audio will be passed back to receiver. So I use the X700 for those titles. Also the PGS subs will not work, just use a .SRT in same folder if you need subs.
of course, if I could force lldv and see with my own eyes I would have posted a comparison a long time ago.lexyz wrote: Mon Dec 28, 2020 9:42 pm Can you force P-led on X700+LG through Vertex thing?
If so you shouldn't rely on my pictures at all and can see difference by your own eyes
there's the LLDV Sony EDID option in my first gen Vertex but unfortunately, I'm not able to make it work. All I get is tv-led.
TsMuxer does not desynchronize the audio/video. I merged the Lord of The Rings movies in a single file. I watched all of them without any sync issue.Roberespa wrote: Mon Dec 28, 2020 3:57 pm
But i do not know why
tsMuxeR desynchronizes the audio with the video. = (
Tsmuxer is actually my favorite tool to mux seamless branching movie because it properly removes overlapping frames.
Roberespa
Can you explain how you did it?RESET_9999 wrote: Tue Dec 29, 2020 4:25 pmof course, if I could force lldv and see with my own eyes I would have posted a comparison a long time ago.lexyz wrote: Mon Dec 28, 2020 9:42 pm Can you force P-led on X700+LG through Vertex thing?
I have Disc 1 and Disc 2 in m2ts with Dolby Vision when I combine them with tsMuxeR, when Disc 2 (which is connected to Disc 1 + Disc 2) starts up the video audio is out of sync.
I open the "add" rings of tsMuxeR.
Then I click "join", add rings2, select M2TS, and start muxing.
As a result, when the second disc should start, the video gets out of sync with the audio.
Please help.
I always use the .mpls file(playlist folder) instead of the m2ts file so that might be the reason why.Roberespa wrote: Tue Dec 29, 2020 5:42 pm
Please help.
Also, make sure that you use the latest nightly tsMuxer and not the old tsmuxer
https://bintray.com/justdan96/tsMuxer/t ... htly#files
So after my latest reply, I decided to give another go to my Vertex. and btw I'm not relying on your picture at all.. I'm just saying that your comparisons with vincent's video means nothing and that you shouldn't rely on itlexyz wrote: Mon Dec 28, 2020 9:42 pm Can you force P-led on X700+LG through Vertex thing?
The firmware was a bit old so I updated it and now forcing lldv works.
I used content(p5 full range DV) that the Shield can actually play properly (not a uhd-bd rip so no red push affecting the output). On my LG C8, I don't really see any difference between the X700 p-led and the Shield p-led.
screenshot comparison: https://screenshotcomparison.com/comparison/9541
blenky
Been away from this thread for a few weeks so trying to catch up.
I understand that the latest MakeMKV (1.15.4) can now remux a MEL DV UHD Bluray.
For FEL a MEL needs to be created. Is the post below still the preferred method or has it been updated? Thanks
https://www.makemkv.com/forum/viewtopic ... 360#p97878
kazuma
can anybody upload a small DV-file of MKV? so we can test?
Re:
Can u do a Soul comparison with the real dv rgb dv-8bit? just for fun.RESET_9999 wrote: Tue Dec 29, 2020 7:00 pmSo after my latest reply, I decided to give another go to my Vertex. and btw I'm not relying on your picture at all.. I'm just saying that your comparisons with vincent's video means nothing and that you shouldn't rely on itlexyz wrote: Mon Dec 28, 2020 9:42 pm Can you force P-led on X700+LG through Vertex thing?
From both playback devices.
Curious too see on your calibrated c8 to see
If differences of dual tone mapping can be observed LLDV vs rgb 8 like Vincent showed.
Roberespa
Updated program tsMuxeR 2020-12-29 Nightly (x64)RESET_9999 wrote: Tue Dec 29, 2020 6:00 pmI always use the .mpls file(playlist folder) instead of the m2ts file so that might be the reason why.Roberespa wrote: Tue Dec 29, 2020 5:42 pm
Please help.
I have done it again as you indicated. I took the .mpls from disk 1 and disk 2 and created a m2ts.
Again there is desynchronization
of the audio with the video just when disc two would enter, as I mentioned.
Don't join the movies together. Keep them separate.Roberespa wrote: Tue Dec 29, 2020 9:08 pmUpdated program tsMuxeR 2020-12-29 Nightly (x64)RESET_9999 wrote: Tue Dec 29, 2020 6:00 pmI always use the .mpls file(playlist folder) instead of the m2ts file so that might be the reason why.Roberespa wrote: Tue Dec 29, 2020 5:42 pm
Please help.
I dont know. The 3 movies are perfectly in sync on my end. both the x700 and on my pc. what media player do you use ?Roberespa wrote: Tue Dec 29, 2020 9:08 pm
I did the extended version if that make a difference. Also, i did it a couple weeks ago, so not really the latest tsmuxer version.. Maybe a bug introduced in the latest version?
Complete name : D:\The.Lord.of.the.Rings.1.The.Fellowship.of.the.Ring.2001.DV.ts
Format : MPEG-TS
File size : 122 GiB
Duration : 3 h 48 min
Overall bit rate mode : Variable
Overall bit rate : 76.6 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video #1
Menu ID : 1 (0x1)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 602 cd/m2
Maximum Frame-Average Light Level : 184 cd/m2
Video #2
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 6
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Audio #1
Menu ID : 1 (0x1)
Format : AC-3 MLP FBA 16-ch
Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Bit rate mode : Variable
Bit rate : 448 kb/s
Maximum bit rate : 4 992 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 732 MiB (1%)
Language : English
Service kind : Complete Main
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
pete19
Re:
you need to use p7 with FEL in order to see differences - because the "problem" occurs when the EL is merged with the BL, and in LLDV this is done by the player/source and it won't be as accurate as tv-ledRESET_9999 wrote: Tue Dec 29, 2020 7:00 pmSo after my latest reply, I decided to give another go to my Vertex. and btw I'm not relying on your picture at all.. I'm just saying that your comparisons with vincent's video means nothing and that you shouldn't rely on itlexyz wrote: Mon Dec 28, 2020 9:42 pm Can you force P-led on X700+LG through Vertex thing?
p5 does not have EL
