Features Request: Output Folder
busthead
Post by busthead » Fri Dec 25, 2020 9:15 pm
Am I the only person copying the DVD Name from the Info box and appending it to Output folder path?
Please add these features:
1. Auto stripping of white space at the end of the Output folder path - rather than throwing an error and associated dialogue.
2. A config option auto-create folder and suppress the "...does not exist. Do you want to create it?" dialogue.
Thx
Re: Features Request: Output Folder
Post by Woodstock » Sat Dec 26, 2020 12:59 am
How do you have your Preferences->Video page set up?
busthead
Post by busthead » Sun Dec 27, 2020 1:53 am
+Custom
[Desired Path Explicitly Listed]
Post by Woodstock » Sun Dec 27, 2020 2:55 am
Custom pretty much means you plan on providing everything after the default path.
Semi-automatic will use the disk name as a directory name, added to the default path.
busthead
Post by busthead » Sun Dec 27, 2020 5:34 pm
Perfect. Thank you.
busthead
Post by busthead » Fri Jan 01, 2021 12:02 am
Any way to suppress the "Directory...does not exist. Do you want to create it?" dialogue?
Post by Woodstock » Fri Jan 01, 2021 1:21 am
Probably not... I can think of several good reasons not to, one of which being that you can ask MakeMKV to create directories (and files) that have leading or trailing spaces, which are a real pain to remove when you discover them later.
