cipher
#3991 Post by cipher » Sat Dec 26, 2020 3:34 am
pete19 wrote: Fri Dec 25, 2020 1:36 am there is no DV metadata being sent with LLDV. The metadata was already used by the device to create the DV image.
best picture will be tv-led, hence letting a full DV capable TV create the DV image. For LLDV, the player has to guess some of the many parameters hence image will be less correct.
Lots of interesting info over the past few pages and I'm trying to catch-up. Does this mean that even if the Shield fixes their color issues with DV content, the DV stream still won't be as accurate as TV led DV?
Also, what exactly is TV-led DV and how do you achieve this on an LG OLED? For the many of us using the Plex ecosystem is there any client that offers this possibility?
Finally, does this LLDV vs TV-led DV difference also extend to other HDR variants like HDR-10?
zxaura1
#3992 Post by zxaura1 » Sat Dec 26, 2020 4:43 am
RESET_9999 wrote: Wed Dec 09, 2020 12:05 pm
Roberespa wrote: Wed Dec 09, 2020 11:46 am Inside the LG menu.
The television model says:
OLED55B6V-Z
and at the end an interesting fact.
Dolby Vision 0.9.0
I also tried MakeMKV v1.15.3 but the TV won't open it.
Demomento only worked (opened it) with Dolby Vision in .mp4
Thanks for answering me.
I wait your answer.
I don't know if the problem will be the file size ... = (
you don't need a ts/mkv file if you play them in your LG B6. stick with the mp4muxer.
DaMacFunkin wrote: Wed Dec 09, 2020 6:07 am
Hi, you don’t say what your playback device is?
TLOTR and The Hobbit are MEL so the easiest way to create Dolby Vision MKV is Makemkv.
LOTR are [s] FEL DV [/s]
Hello there...
Does anyone knows why my LG E6 plays many DV movies in a green tint (like all Mission Impossible etc) and if there is a solution to it?
Thanks in advance
cipher
#3993 Post by cipher » Sat Dec 26, 2020 5:06 am
Ok, just watched this video from Vincent explaining the difference between TV-led and Player-led DV so I can see where TV-led would be the better option...
https://www.youtube.com/watch?v=e_a77zJTrO4
Also, I found the following quotes on the nVidia forums:
The Shield supports both and will do TV-led if your TV supports it...
It does TV-led for me and I still get the slight red push.
Hi I didn’t think the Shield was doing TV-led with my C9 but it actually is, shame they can’t nail this on shield...
Therefore, assuming my LG B7 is capable of TV-led DV and the Shield can detect this and send the DV for the TV to process, is TV-led DV the result when using a Plex client that plays DV on the Shield? I'm currently switching between the native Plex client and the Kodi plex client on my Shield and want to make sure I'm aware of any differences here when playing DV mkv's.
#3994 Post by shawnc22 » Sat Dec 26, 2020 5:16 am
cipher wrote: Sat Dec 26, 2020 5:06 am Ok, just watched this video from Vincent explaining the difference between TV-led and Player-led DV so I can see where TV-led would be the better option...
Yes, it should be using TV-led DV on your B7
Mortenjorstad
#3995 Post by Mortenjorstad » Sat Dec 26, 2020 11:49 am
Can someone please share tsmuxer 05.06 fix :D
lexyz
#3996 Post by lexyz » Sat Dec 26, 2020 1:28 pm
I share this picture to discuss possible reasons why Shield TV Player-led STDL very close to Oppo TV-led DTDL
Any ideas? :roll:
Pay attention on yellow beak
#3997 Post by Manixx2020beyound » Sat Dec 26, 2020 3:09 pm
lexyz wrote: Sat Dec 26, 2020 1:28 pm I share this picture to discuss possible reasons why Shield TV Player-led STDL very close to Oppo TV-led DTDL
Any ideas? :roll:
What type of uhd Tv is the tv-led dv ?
Sorry but oppo don’t look that good to me.
X700 takes it all lol.
#3998 Post by RESET_9999 » Sat Dec 26, 2020 3:21 pm
Any ideas? :roll:
top picture is from the Vincent video ??
As I told you in PM, you can't compare the images from his video/TV with the images from your camera/TV. it means nothing
Not the same room, not the same tv, not the same camera / settings etc...
On my calibrated monitor, all 4 pictures look completely different and the shield picture doesnt look at all close to the oppo tv-led but as i said, its meaningless.
zxaura1 wrote: Sat Dec 26, 2020 4:43 am Hello there...
Thanks in advance
it's related to the metadata.. If i remember correctly , the combination of Mastering display luminance 1000 nits and P3 color causes the green screen issue on 2016 OLED LG TVs. The solution is an external player like the x700, the shield or FirestickTV.
it was discussed a long time ago when the mp4muxer came out.
#3999 Post by RESET_9999 » Sat Dec 26, 2020 5:18 pm
Manixx2020beyound wrote: Sat Dec 26, 2020 3:09 pm
I don't think so... Vincent said he tested the Panasonic bluray player as well.
Also,  Stacey Spears (creator of Spears and Munsil) confirmed that all the bluray players will have this issue when doing player-led DV.
EDIT: Also it sounds like @pete was right about FEL being 422, or Don't I understand whats Stacey is saying ?
glc650
#4000 Post by glc650 » Sat Dec 26, 2020 7:14 pm
shawnc22 wrote: Wed Dec 23, 2020 9:16 am
MastaG wrote: Wed Dec 23, 2020 9:12 am So which players are capable of playing FEL remuxes from network sources (Plex/Emby/SMB), e.g. the full deal retaining the 12bit 4000nits final picture like when playing the original disc?
e.g. remuxed into a TS or MKV container so I can add a high def audio track?
From network? The oppo and that's it.
I just acquired a Sony UBP-x800M2 and it can play m2ts (BDMV folders aren't supported) DV remuxes created by tsMuxeR over the network (albeit via DLNA only - I'm using built in DLNA app on my Synology NASes to serve up content to the X800M2).
PlatypusW
#4001 Post by PlatypusW » Sat Dec 26, 2020 7:15 pm
glc650 wrote: Sat Dec 26, 2020 7:14 pm
I just acquired a Sony UBP-x800M2 and it can play m2ts (BDMV folders aren't supported) DV remuxes created by TSmuxeR over the network (albeit via DLNA only - I'm using built in DLNA app on my Synology NASes to serve up content to the X800M2).
Does it have 100mbit Ethernet though? That will be too slow for some titles. X700 I believe is the same.
glc650
#4002 Post by glc650 » Sat Dec 26, 2020 7:21 pm
PlatypusW wrote: Sat Dec 26, 2020 7:15 pm
It does, but it also supports 802.11ac (WiFi 5) albeit only 1x1 but that's still enough to get me well over 100mbps (connected to my UAP-AC-HD at ~300 or higher every time I've checked).
bgalakazam
#4003 Post by bgalakazam » Sat Dec 26, 2020 10:50 pm
I found the wifi on both my C8 and the "MIMO" 2.4GHz wifi on the X700 slower than 100Mbit ethernet. They stuttered more streaming from my Synology than the wired connection. This is from an enterprise grade access point <1m from the TV/X700. For the <5 titles I have watched in the past couple years that required more than 100Mbit I have just used a USB thumb drive. Glad to hear the X800M2 has better performing wifi.
Sony X700 -> Onkyo TX-RZ830 -> LG C8
pete19
#4004 Post by pete19 » Sat Dec 26, 2020 11:02 pm
Any ideas? :roll:
shield image has incorrect hue/saturation on the beak (compared to tv-led), besides the color artifacts/clipping
lexyz
#4005 Post by lexyz » Sun Dec 27, 2020 6:12 am
Guys, don't compare hue sharpness, brightness or clipping
I can't set my camera and TV to match Vincent's
Do not make conclusion about this parameters
:D
Only thing to look at is the shape of yellow spot
Zoom in if you're on mobile.
Can't you see the similarities and differences?
