TENET audio problem shows only DD stereo in all its versions after analyzing disk. This is before ripping.
The box mentions DTS HD Master audio next to Dolby audio.
Still did the ripping to no avail. Good video, but stereo sound.
Checked other blu-rays, but they show the general choices like DTS, Dolby, AC3 and so on. So it definitely is the Tenet Blu-ray
interacting with MakeMKV.
I have a registered MMKV version ( bought)
What can I do?
preserve
Re: TENET audio problem shows only DD stereo
What country release do you have? Are you using the original disc, or something else?kyrill wrote: Sat Dec 26, 2020 1:10 pmTENET audio problem shows only DD stereo in all its versions after analyzing disk.
Asuming you aren't using the down-mix feature...
The Tenet Blu-ray should look something like this. The DTS-HD MA 5.1 track is the main audio, the second track checked in the screenshot is 5.1 Descriptive Audio.mike admin wrote: Sat Nov 14, 2020 12:35 pm ... audio down-mix feature. Enable expert mode, and select AAC-stereo profile . For each audio track you will have an option to save the original AND/OR stereo copy. And you can do this for already existing MKV file, just open the MKV file in MakeMKV.
Can you post a screenshot, matching the above, of what you're seeing?
And/or run the disc structure diagnostic here, and post the results.
Using: ASUS BW-16D1HT 3.00
kyrill
thx for the fast reply.
It is an original European disk (Netherlands) ( back side of box) in French and English
kyrill
I see in yr example 40.2 GB
I have a disk wit 2x 19 Gig??
koberulz
I think you've put in the Special Features disc, not the Movie disc.
kyrill
The first time this happens to me, there is always a first time...
