MyXTreamer cannot show selected subtitles
Phoek
Post by Phoek » Mon Jan 17, 2011 7:38 am
When I convert my DVDs I have no problem playing them back on my XTreamer, in any language or subtitles embedded.. bu whenever I convert one BluRay, my XTreamer cannot show the selected subtitle I choose from the list. VLC on my PC is able to display it... On the XTreamer Forum, they told me that Xtreamer doesn't support PGS Subtitles...I have tested my files on 2 other different Media HD.. and same result... after having searched on the net, it seems non or perhaps almost none can s upport PGS Subtitles.
Do you plan to change the subtitles coding inside MKV ? because my mean to buy a licence of MakeMKV depends on the answer :)
best regards
ygi
Re: MyXTreamer cannot show selected subtitles
Post by mike admin » Mon Jan 17, 2011 11:02 am
Hi. MakeMKV just copies subtitles in a format they're encoded on a disc. Blu-ray uses PGS subtitles. Presently MakeMKV can't convert them to any format. That is likely to change in future but how soon is yet unknown.
