I downloaded and installed v1.6.3 (Windows XP 32-bit SP-2). Upon starting Visual Just-In-Time Debugger popped up with this message: "An unhandled win32 exception occured in makemkvcon.exe [3700]". I was prompted if I wanted to bring up Visual Studio 2008 debugger. Since I don't have Visual Studio 2008 installed on my machine the debugger didn't come up and makemkv exit ("Fatal error occured, program will now exit"). I tried uninstall and re-install but to no avail. What's the cause? Is Visual Studio 2008 required by makemkv?
thanks,
MakeMKV 1.6.3 doesn't start
- Contact:
Re: MakeMKV 1.6.3 doesn't start
MakeMKV has nothing to do with Visual Studio. It's likely that it crashes because of some other problem in your system.
