Archgon MD-8107S-U3YC-UHDB-K
TonyTheTiger
#1 Post by TonyTheTiger » Sat May 09, 2020 7:57 pm
Hi There,
I have been reading through the forum and I know there are already dozens of posts on this, but I think that in itself makes it all the more confusing for a newbie like myself.
I was hoping someone could provide me with a link to the correct software for flashing the following drive, I want to make absolutely sure I use the correct and latest one.
Thanks in advance for your help
Tony
Screenshot 2020-05-09 at 20.55.15.png (75.51 KiB) Viewed 19037 times
jonghotti
Re: Archgon MD-8107S-U3YC-UHDB-K
#2 Post by jonghotti » Sat May 09, 2020 9:03 pm
The firmware you need can be found here, first topic, stickied at the top of this sub forum.
https://www.makemkv.com/download/mk-fir ... 200415.zip
Hammer20
#3 Post by Hammer20 » Fri Dec 25, 2020 7:45 pm
Hi there,
I have the same Drive MD-8107S-U3YC-UHDB-K!! Further I am also new and have never flashed a drive before!
May I ask the question how you flash this drive? How do I get the flashed version installed on the drive?? Is the BU40N-N the right folder or the BU40N-U??
Thanks a lot.
st4evr
#4 Post by st4evr » Fri Dec 25, 2020 8:37 pm
Hammer20 wrote: Fri Dec 25, 2020 7:45 pm Hi there,
Thanks a lot.
Please pay attention to and take the time to read the guides/info posts/stickie posts across the forum, including the warnings noted within. They are there to try and answer these common questions and help avoid problems prior to taking such actions. We can’t stress this enough. You can start here:
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
jonghotti
#5 Post by jonghotti » Fri Dec 25, 2020 9:18 pm
What he said. The only way could make it easier for end users if if we were to send someone over to do it for you on an appointment basis.
Hammer20
#6 Post by Hammer20 » Sat Dec 26, 2020 10:05 pm
Thanks for the incredible quick answer! You guys are awesome!! I paid close attention to and took the time to read the guide info and post on how to flash my drive. The follwing post was my rescue https://www.makemkv.com/forum/viewtopic ... B+K#p73185.
I used Modified Asus Patcher to flash it with the BU40N-U, respectively the HL-DT-ST-BD-RE_BU40N-U101-MM01201-211711301153.bin.
IT WORKED PERFECTLY!!! Now I can ripp 4k Blu Rays.
jonghotti
#7 Post by jonghotti » Sun Dec 27, 2020 2:44 pm
Good job! Enjoy your drive.
