Star Trek TOS Season 1
WildCat
#1 Post by WildCat » Sat Dec 19, 2020 2:30 pm
Hi, I'm writing to you because using your product I had problems with the first season in Bluray of Star Trek Tos, particularly with only two titles and both with the same number and wondering if anything can be done. In addition, is there any way to insert the extrapolation of pgs and vob subtitles into srt?
Reason: Renamed Subject
Re: Feature request
#2 Post by Woodstock » Sat Dec 19, 2020 3:40 pm
Dual episodes on Star Trek:TOS is because there is an "as broadcast" and a "new special effects" version of every episode. You can chose the one you want, but it is simpler to rip both. I put an "a" at the end of the episode number for the new effects versions.
MakeMKV does not do optical character recognition (OCR) on subtitles, but there are other tools you can use for that.
Re: Feature request
#3 Post by dcoke22 » Sat Dec 19, 2020 4:13 pm
If you've extracted your PGS subtitles, one tool you can use is https://subtitletools.com
There are undoubtedly others as well.
WildCat
Re: Feature request
#4 Post by WildCat » Sun Dec 20, 2020 2:41 pm
Woodstock wrote: Sat Dec 19, 2020 3:40 pm Dual episodes on Star Trek:TOS is because there is an "as broadcast" and a "new special effects" version of every episode. You can chose the one you want, but it is simpler to rip both. I put an "a" at the end of the episode number for the new effects versions.
I know, but on both disc 3 and disc 4, tracks 2 (1) can't be completely extrapolated
preserve
Re: Feature request
#5 Post by preserve » Sun Dec 20, 2020 5:11 pm
I’m unclear what the exact issue you’re having is. I had no issues with these discs. It would help if you showed the log and described the problem you’re having in more detail.
Using: ASUS BW-16D1HT 3.00
WildCat
Re: Feature request
#6 Post by WildCat » Mon Dec 21, 2020 5:29 pm
preserve wrote: Sun Dec 20, 2020 5:11 pm I’m unclear what the exact issue you’re having is. I had no issues with these discs. It would help if you showed the log and described the problem you’re having in more detail.
How do I send the log?
WildCat
Re: Feature request
#7 Post by WildCat » Mon Dec 21, 2020 5:35 pm
error
error
Immagine 2020-12-21 183357.png (161.33 KiB) Viewed 29897 times
preserve
Re: Feature request
#8 Post by preserve » Tue Dec 22, 2020 2:11 am
MakeMKV is having difficulty reading the disc, it's encountering corrupt or invalid offsets.
The troubleshooting in this thread may be of some help: viewtopic.php?f=8&t=15055
WildCat
Re: Star Trek TOS Season 1
#9 Post by WildCat » Fri Dec 25, 2020 9:10 am
possibility of not being able to extract mkv files from full bluray online (folders) Star Trek Tos, mainly hdd use powered by usb. So I ask, if you can integrate a slower reading mode to avoid the presence of errors that might otherwise be present during normal speed? Alternatively, do you advise me to get an hdd with wall power?
preserve
#10 Post by preserve » Fri Dec 25, 2020 9:17 am
WildCat wrote: Fri Dec 25, 2020 9:10 ampossibility of not being able to extract mkv files from full bluray online (folders) Star Trek Tos
Are you ripping from discs, or from a folder backup of the discs? If you're ripping from a folder backup of the discs, did you make that backup yourself using MakeMKV from the original discs? If you didn't, it's possible there is an issue with the folder backup.
WildCat wrote: Fri Dec 25, 2020 9:10 ammainly hdd use powered by usb ... presence of errors that might otherwise be present during normal speed? ... do you advise me to get an hdd with wall power?
As mentioned above, MakeMKV is having trouble reading the file due to corrupt or invalid offset. It doesn't seem like an issue with read speed or the fact that the drive is USB powered.
WildCat
#11 Post by WildCat » Fri Dec 25, 2020 10:55 am
preserve wrote: Fri Dec 25, 2020 9:17 am
I procure them online, in some cases I solved using only mkvtoolnix but this eliminated the other views or modes es star wars introduction .... in a galaxy far away
preserve
#12 Post by preserve » Fri Dec 25, 2020 1:43 pm
WildCat wrote: Fri Dec 25, 2020 10:55 amI procure them online
In that case, the solution to the issues you're experiencing is to purchase the original discs.
WildCat
#13 Post by WildCat » Fri Dec 25, 2020 1:50 pm
preserve wrote: Fri Dec 25, 2020 1:43 pm
alternatively, other programs (mkvtoolnix, dvdfab). anyway i didn't even burn bluray or bluray uhd
