TENET UHD RB - Failed to open disk
TheShoe
Re: TENET UHD RB - Failed to open disk
#91 Post by TheShoe » Wed Dec 23, 2020 12:09 pm
Amazon (US) version "64DA" still not working.
Bummer.
EDIT:
The disc won't even back up properly without decryption (makemkv says it backed up but one file failed hash check; however the disc never fully backs up - odd behavior) - no amount of cleaning helped, so exchanging it.
hedbert
#92 Post by hedbert » Wed Dec 23, 2020 2:56 pm
A470 is working now too!! Thank you!
preserve
#93 Post by preserve » Wed Dec 23, 2020 3:54 pm
hedbert wrote: Wed Dec 23, 2020 2:56 pmA470 is working now too!! Thank you!
Confirmed! I had no issues making a backup, and I just ripped from the backup with no issues... It's a Christmas miracle! Just on time lol... I'll be watching this tomorrow night! :D
Using: ASUS BW-16D1HT 3.00
TORRRRR
#94 Post by TORRRRR » Thu Dec 24, 2020 1:05 am
Original poster here: Thank you Mike! MKB20_v76_Tenet_A470.tgz
100% successful backup.
rbphelan
#95 Post by rbphelan » Thu Dec 24, 2020 2:20 am
TheShoe wrote: Wed Dec 23, 2020 12:09 pm Amazon (US) version "64DA" still not working.
Bummer.
EDIT:
This is the version that I have and it's working (MKB20_v76_TENET_64DA). Good call to have it exchanged.
TheShoe
#96 Post by TheShoe » Thu Dec 24, 2020 9:06 pm
Closing the loop - new (exchanged) set arrived today from Amazon.
Backing up fine.
enzolt
#97 Post by enzolt » Thu Dec 24, 2020 10:02 pm
I tried two copies..
First one from Best Buy, couldnt rip and couldnt backup..
Exchanged it for another copy...still couldnt rip and still couldnt backup...
Same issue with invalid CDB
preserve
#98 Post by preserve » Fri Dec 25, 2020 6:28 am
Since many are watching this one with subtitles, the disc doesn't include non-SDH subtitles, and I found the SDH to be quite excessive compared to other discs where it's minimal, I present English SRT Subtitles for North America UHD / Blu-ray minus the SDH portions, for anyone who's interested:
http://s000.tinyupload.com/index.php?fi ... 1057911043
charlie62
#99 Post by charlie62 » Fri Dec 25, 2020 1:25 pm
Is the UK version good to go or is it still waiting for a key
simon_ldt
#100 Post by simon_ldt » Sat Dec 26, 2020 1:03 pm
The Nordic version is decrypted (I got the Finnish steelbook edition).
Had a bit of hassle ripping this one (although nowhere near as bad as Black Hawk Down or Fury). Tried it on 2x speed and encountered an error around 62gb into the main movie file (the rip completed, which is usually a good sign rather than it getting stuck and failing altogether).
Gave the disc a good clean and tried again. Same spot it got stuck this time so I manually aborted it. Decided to try unlimited speed but the drive did not like it at all. It wanted to get going but kept stalling (drive was making a revving sound like it wanted to take off but it just couldn't).
Aborted it manually and decided to try at around 5x speed. I wasn't expecting much but it actually got past the 60gb mark and completed without errors, took about 1hr at that speed.
Very strange as I did not clean the disc again after the initial 1 time I did. Just proves to me how delicate and finicky these discs are. I only give up on a disc after about 10 attempts and at least 3 cleans.
TheShoe
#101 Post by TheShoe » Mon Dec 28, 2020 2:45 pm
The QC on UHD is terrible.
Tenent was one of the worst for me; I just returned for an exchange the Lord of the Rings 4K set because one of the discs refused to rip at a certain point.
I’ve had easily 20 UHD discs fail to backup with at least one well past the return/exchange date so I actually bought the title a second time (Guardians of the Galaxy 2). Granted I have a few hundred UHDs, but when compared to bluray, the failure rate is very high from my experience. In fact to this day I still only have one bluray disc that makemkv can’t back up — Hitchikers Guide to the Galaxy (movie, not the TV series). It plays perfectly fine. It just won’t back up.
SyrimSloane
#102 Post by SyrimSloane » Tue Dec 29, 2020 11:26 am
simon_ldt wrote:The Nordic version is decrypted (I got the Finnish steelbook edition).
How do you change drive speed?
#103 Post by d00zah » Tue Dec 29, 2020 2:28 pm
SyrimSloane wrote: Tue Dec 29, 2020 11:26 am How do you change drive speed?
MakeMKV drive speed control
stuckinkodiagain
#104 Post by stuckinkodiagain » Tue Jan 05, 2021 3:15 am
My advice to anyone having troubles with Tenet (apart from decryption) is to make an unencrypted backup first, and then get the MKV from the backup. Don't just try to get the MKV directly from the disc.
Same problem happened for me with the UHD import from the UK of Crash (1996). But getting the MKV from a full disc backup worked perfectly.
by96$
#105 Post by by96$ » Wed Jan 13, 2021 11:34 pm
I just received Tenet from Amazon and am having problems ripping it or backing it up. I continually get an error message:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading...
Again, this happens with ripping or just backing up. I have cleaned the disc (will try that again) and have never had this problem on any other disc.
UPDATE: I cleaned the disc several times and tried backing it up. Nothing worked. Always got the same error message. Once, it got half way through the back up and then failed. I have requested a new copy from Amazon to see if a different disc works. Any help would be appreciated.
