What adapters won't work in windows for flashing won't work in mac os thats why I have that stuff posted.dash16 wrote: Tue Jun 02, 2020 12:22 am
I've got the drive connected via a VanTec CB-ST00U3, which apparently won't work for firmware flashing in Windows but I figured I'd try my luck in macOS,
Attempting to flash in macOS
Re: Attempting to flash in macOS
o-ver
Sorry, I forgot o mention: Flashing did not work with two adaptors laying around. I ordered a USB3.0B-to-USB-C-Cable to flash succesfully direct connected to my MBP!dash16 wrote: Tue Jun 02, 2020 12:22 am I'm considering lugging out an old PC and getting that up and running for a direct SATA connection to the drive simply to firmware flash, but before I tear apart my garage looking for all that mess I figured I'd see if I'm missing something dumb first.
j_dot
Apologies for bumping an old thread, but I wanted to post a full set of instructions for someone looking to flash a drive on MacOS X:
Start by navigating to the MakeMKV application
Get the latest SDF file; write it to the local directory (you can also write it to your home directory or someplace more convenient)
Find the drive identifiers
Look for your drive. You should see something like this (in this example, I have two drives attached, each with a disc in; as the first post in the thread points out, though, the /dev/rdisk* won't work):
I was looking to flash the WH16NS60, and I had downloaded the latest MK firmware pack, so:
Note that I needed to use enc because the 1.03 firmware is encrypted; leave that off if your current firmware is unencrypted.
After doing this, and turning my drive off and on just in case, I was able to rip from a UHD disc. (And, for faster reads: https://www.makemkv.com/forum/viewtopic.php?p=93341 )
cd /Applications/MakeMKV.app/Contents/MacOS
curl -O "https://makemkv.com/sdf.bin"
./makemkvcon f --list
Found 2 drives(s)
00: /IOBDServices/65961856, /dev/rdisk2, /dev/rdisk2
PIONEER_BD-RW___BDR-212U_1.00_SFDL000221WL
01: /IOBDServices/C01417F1, /dev/rdisk5, /dev/rdisk5
HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_KLFK7LA5541
./makemkvcon f -d /IOBDServices/C01417F1 -f sdf.bin rawflash main,enc -i ~/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
pmhCH
Thanks for this fine "how-to-do"
My problem is only, that my drive is not in the patch list, even if is has the status "possible, not yet enabled" in makemkv:
Can anybody help me here?
Samsung 78" (still with 3D), ATV 4k (64Gb) running Infuse, Hue Sync + Sonos "5.1"
Your drive can not be made UHD compatible. Those must be based on the MT1959 chip.
pmhCH
Yes, just saw MIke's post about those Samsung drives and mine seems not supported and probably never will be:
So one wonders why it still says "Possible, not yet enabled" in makemkv...
It means that someday (now seems unlikely), your drive may support libredrive (but still, it will never be UHD capable!)pmhCH wrote: Sat Oct 10, 2020 11:43 am Yes, just saw MIke's post about those Samsung drives and mine seems not supported and probably never will be:
aeharding
Just flashed my LG WH16NS40 on an m1 (arm-based) 2020 Mac Mini with Big Sur 11.1. Couldn't be easier. Cheers!j_dot wrote: Wed Oct 07, 2020 12:22 am Apologies for bumping an old thread, but I wanted to post a full set of instructions for someone looking to flash a drive on MacOS X:
bachelorbob
HOW did you extract sdf_0000006d.bin? I have sdf.bin. Replacing 'sdf_0000006d.bin' with 'sdf.bin' did not work.
bachelorbob
Using this exact command line, except for my personal paths to files (e.g. '/Applications/MakeMKV/firmwares/DE_LG_BU40N_1.00.bin') and drive ID (e.g. '/IOBDServices/82D49293'), I get:j_dot wrote: Wed Oct 07, 2020 12:22 amCode: Select all
Unable to load sdf.bin
Internal error 0xffffffff
Does anyone have any idea why?!
You might try fully qualifying the path to sdf.bin on your system.
I assume you've read this: viewtopic.php?f=4&t=23129
bachelorbob
I needed the full path to 'sdf.bin'
/Applications/MakeMKV.app/Contents/MacOS/makemkvcon f -d /IOBDServices/82D49293 -f /Applications/MakeMKV/sdf.bin rawflash main,enc -i /Applications/MakeMKV/firmwares/DE_LG_BU40N_1.00.bin
100% Operation finished
Done successfully
…MakeMKV still shows a LibreDrive status of "Possible, not yet enabled"
Help?
bachelorbob
Got rid of the "enc" part of the command line. (My drive being quite new, I expected it to be firmware encrypted.)
Viola!
So, it *IS* possible to firmware flash on a Mac (OS X.13.6), without a virtual/boot camp Windows. For the record, my drive was an 'hp HLDS BDRE BU40N' with firmware BW42. It now considers itself an 'HL-DT-ST BD-RE BU40N' with firmware 1.00.
I am staying on FW 1.00 because I use DVDFab to do whole disc copies (.ISO). If anyone knows that DVDFab will work with a later firmware (1.03, 1.04), or a reason to use an MK firmware, please let me know.
Viola!
bachelorbob
I also successfully flashed my BU40N on a MacBook Pro using this generic, low-quality, low-cost USB3 enclosure from AliExpress:
bachelorbob
I have successfully copied (to an ISO image) the film '1917' from a UHD disc, using my MacBook Pro mid-2012, an external BU40N flashed to FW 1.00, and DVDFab 11.0.7.5. That said, I never attempted to extract a UHD under the stock FW of BW42. This was the first UHD I had in hand, and it arrived after I downgraded the firmware.
