doesn't work with 'First Blood'
Kassad
Post by Kassad »
It starts the make mkv process then stops about 30 seconds into it. This is the very first Rambo movie. For some reason it works on all the rest but not 'First Blood'. I have anydvd running in the backround.
Kassad
Re: doesn't work with 'First Blood'
Post by Kassad »
not sure how to copy/paste into here, but here are two lines from the output log:
FAILURE: Code 49 at H~ZO_;Mv#7<syL=(s(:121265131
FAILURE: Code 0 at pN3)f'Pk65@sHkp_mP>i\:213132123
LIBMKV_TRACE:Exception: Error while reading input
Failed to save title 0 to file D:/ *blah blah blah*
Post by mike admin »
Please provide some more info on the disc - what is disc region, what country it was released? Also it looks like you copied log lines incorrectly - please try again and cut&paste the log.
rpkkur
Post by rpkkur »
Was this solved? I ran into the same problem today with 1.4.3
Saving 1 titles into directory C:/Video/First Blood
FAILURE: Code 49 at XM8Ng}0VQuP'y`rlhFT:121265131
FAILURE: Code 0 at I)BRPM\#9|ci9oq~*>^<V:121264211
Failed to save title 0 to file C:/Video/First Blood/title00.mkv
0 titles saved, 1 failed
I tried it with AnyDVD running and Not running and both failed. It failed first with the previous version also. This is Region Code 1 i would imagine since this is a US disc.
The error says that mpeg video stream is corrupted. We'll investigate. Thanks for reporting.
rpkkur
Post by rpkkur »
Thanks Mike for looking into it. I also tried it with 1.4.4 and here is the error to help you in your investigation
FAILURE: Code 49 at ?.I5cmx7@spsY2F@vBy:121265131
FAILURE: Code 0 at H;U8z4wnSOPr&,I=C%6J[:121264211
Failed to save title 0 to file C:/video
