The m2ts files triggers the HDR fine. Even the same movie, if i use full bluray m2ts files works ok but remuxes mkv does not trigger it .
If the same on kodi or plex
MKV does not trigger HDR
Re: MKV does not trigger HDR
If you use the most recent version of MediaInfo (https://en.wikipedia.org/wiki/MediaInfo) it'll tell if there's HDR and/or Dolby Vision in your MKV file.
Here's a DV example:
Here's a HDR10 only example:
This will tell us if it is a problem with the MKV file or something with your playback chain; either the hardware or software of the player.
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID : V_MPEGH/ISO/HEVCCode: Select all
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC-
rodrigo081089
General
Unique ID : 246997909691546086932214234810550478505 (0xB9D2112A081280CBCA910B41E13266A9)
Complete name : D:\UHD\Anna_t00.mkv
Format : Matroska
Format version : Version 2
File size : 65.9 GiB
Duration : 1 h 58 min
Overall bit rate mode : Variable
Overall bit rate : 79.3 Mb/s
Movie name : Anna
Encoded date : UTC 2020-12-20 04:11:20
Writing application : MakeMKV v1.15.3 win(x64-release)
Writing library : libmakemkv v1.15.3 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Bit rate : 74.4 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.374
Stream size : 61.8 GiB (94%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 632 cd/m2
Maximum Frame-Average Light Level : 250 cd/m2
Original source medium : Blu-ray
Format : Matroska
Movie name : Anna
Video
Format : HEVC
Color space : YUV
Bit depth : 10 bits
Language : English
Default : No
Forced : No
rodrigo081089
Format : HEVC
jayf95
What device are you using to playback? You can try updating to makemkv v1.15.4 but I had no issues playing back HDR MKVs on my 1.15.3 so idk what your issue is. The file definitely has HDR available. So I'm thinking theres an issue with your playback device/method.
