Alita: Battle Angel 4K Correct Playlist?
Thornback
Re: Alita: Battle Angel 4K Correct Playlist?
Post by Thornback »
lwndow wrote: Sun Aug 18, 2019 5:23 pm
buggystick wrote: Sat Aug 10, 2019 4:26 am So I recently bought Alita: Battle Angel from Amazon and for some reason the disc is not UHD. It has both the bluray and the 3D disk, but makemkv isn't showing a 4K playlist, just 1080p. This disk is brand new, just took the shrink wrap off and it says "4K UltraHD" at the top...
Did I somehow get a non UHD disk in a UHD box?
How did you get the light descriptions to show up in parens next to the titles? Very cool.
I would like to know this too please.
sharpie00
Post by sharpie00 »
on a mac, install homebrew (if you don't already have it installed...search for homebrew on google).
then run this command in your terminal window:
brew cask install adoptopenjdk/openjdk/adoptopenjdk8
once completed, open up MakeMKV and go to Preferences > Protection > Custom Java executable location and enter this path:
/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
Restart MakeMKV and you should be good to go.
blurayfan2019
Post by blurayfan2019 »
You may already have the version you need without installing another version. Look at /Users/user/MakeMKV_log.txt. You should see something like this:
Found java version=12.0.2 path=/Library/Java/JavaVirtualMachines/jdk-12.0.2.jdk/Contents/Home/bin/java
Found java version=1.8.0.221 path=/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
For some reason, the app chooses the first version, which causes the error. Copy and paste the path of the second version (/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java), which is the correct version, into MakeMKV preferences->Protection->Custom Java executable location. This worked for me.
lwndow
Post by lwndow »
Thanks so much for posting this. For those that were curious like me, since there are multiple versions of the JDK:
It does need to be JDK version 8, versions 11 & 12 will not work the same way. After cask installing, mine installed to
/Library/Java/JavaVirtualMachines/adoptopenjdk-8.jdk
not to:
No need to make the symlink, placing
/Library/Java/JavaVirtualMachines/adoptopenjdk-8.jdk/Contents/Home/bin/java
in the MakeMKV config works just as well.
Thanks again, what a time saver!
blurayfan2019
Well, as I already pointed out
works just fine without installing jdk 8.
ksalno
Post by ksalno »
Trying to rip my first 4K UHD disc and using Alita to learn. I've ripped using Makemkv to a USB drive and attached that to an Oppo 205 for playback. I get video but no audio. I tried to minimize the size of the file, so I only ripped the Main Feature with 7.1 and 5.1 audio. No subtitles and no foreign languages. Am I missing something critical for audio?
blurayfan2019
That's really odd. You didn't select the Title yet you got video. Try selecting the title and the audio.
ksalno
Post by ksalno »
blurayfan2019 wrote: Sun Oct 13, 2019 6:26 pm That's really odd. You didn't select the Title yet you got video. Try selecting the title and the audio.
I didn't have the title checked when I took the screenshot but I did when I actually ran the MakeMKV. I figured out the problem. I had the Oppo 205 Audio HDMI out set to force Bitstream instead of Auto. Funny enough an Atmos demo file I have on USB stick works fine but that was an MP4 file format. Once I switched the Oppo to Auto, the 205 started sending an LPCM stream to my processor and it decoded it as Atmos 7.1.
blurayfan2019
Oh, good that that was all it was.
granular.mandate
Post by granular.mandate »
English:
Source file name: 00800.mpls
Segment map: 687,688,674,689
Source file name: 00801.mpls
Spanish:
Source file name: 00802.mpls
Segment map: 692,688,18,689
Source file name: 00804.mpls
Segment map: 691,688,15,689
French:
Source file name: 00803.mpls
Segment map: 6,688,21,689
German:
Source file name: 00805.mpls
Segment map: 4,688,674,689
Italian:
Source file name: 00806.mpls
Segment map: 690,688,17,689
Russian:
Source file name: 00807.mpls
Segment map: 694,688,19,689
Polish:
Source file name: 00808.mpls
Segment map: 693,688,674,689
