Asus BW-16D1HT 3.03
Billbraskey
Asus BW-16D1HT 3.03
Post by Billbraskey »
Hi. Noob here!
I have just purchased the Asus BW-16D1HT and when I started Makemkv, it shows that I have firmware 3.03. (Please see attached picture for confirmation.)
From reading a bit on these forums, it sounds like I should install the 3.10 MK firmware. Can someone help me out and advise which flashing tool to use(with link) as well as the steps to follow (can I go straight to 3.10MK from 3.03 or is there an intermediate step)? Also, if you can provide a link to the firmware, it would be much appreciated!
st4evr
Re: Asus BW-16D1HT 3.03
Post by st4evr »
Please pay attention to and take the time to read the guides/info posts/stickie posts across the forum, including the warnings noted within. They are there to try and answer these common questions and help avoid problems prior to taking such actions. We can’t stress this enough. You can start here:
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
And read up on the SDF Tool linked within that guide for flashing.
