The Next Karate Kid - "Input parameter is incorrect (459)"
DrOct
#1 Post by DrOct » Fri Oct 23, 2020 12:16 am
I just bought this movie (The Next Karate Kid) and can't seem to get it to rip no matter what I try.
When it first reads the disc I get a whole bunch of them. Then when I try to rip the (one) title on it, I get:
Error 'Internal error - Input parameter is incorrect (459)' occurred while reading '/dev/rdisk12' at offset '23579211776'
udf: node fe/efe failed!
Unable to open file '/BDMV/STREAM/00001.m2ts' in OS mode due to a bug in OS Kernel. This can be worked around, but read speed may be very slow.
It then spends a while working through ripping the title, and then at the end fails.
I've never had this kind of issue with a disc before. Any ideas what it could be? I've looked at it and it doesn't appear scratched or scuffed or dirty in any way.
DrOct
Re: The Next Karate Kid - "Input parameter is incorrect (459)"
#2 Post by DrOct » Fri Oct 30, 2020 11:53 pm
So a bit of follow up: For some reason it hadn't occurred to me initially to try different drives/players. I did (I have a few older Blu-Ray drives still sitting around) and it wouldn't work in any of them either, same problem. Then I tried it in the blu-ray player attached to my TV which has always been pretty well able to handle any disc I throw at it. It wouldn't play there either.
So I returned it and got a new copy today and... exact same thing. Won't play in my Blu-Ray player, won't rip in any of my drives. I figured one defective disc wasn't too surprising, but two? I don't see any reviews or anything mentioning this, but I now have two totally new copies of this disc that have been defective. It's really quite surprising.
I also noticed the bottom side of the discs (which I have cleaned) are a different color than most discs I've looked at. Instead of the blue-ish or silvery look of most BD's it's two different tones of a pretty dark grey. Very odd. If anyone has any insight into what might be happening or has any suggestions about what to do about it I'm all ears!
S.p.e.c.t.r.e.
#3 Post by S.p.e.c.t.r.e. » Thu Dec 17, 2020 1:46 am
Any update on the UDF: node fe/efe failed error?
Joslyn5
#4 Post by Joslyn5 » Mon Dec 21, 2020 3:49 pm
If this is the one from Amazon.com I ordered it a few months back and tried it in all three of my drives multiple times but had no success. it looked like a bootleg copy as it was on a BD-R disc that is why the color is different from most retail disc also the disc label looks like crap and was lazy with just text on a high quality printable side so I returned it and bought it from Amazon.de which the disc looks like what I would normally see as a retail disc and was able to copy that one with no problem the first try
