Flash 1.03MK, then flash WH16NS60 1.02MK. The latter is supposedly the fastest firmware for this drive.matterno wrote: Tue Dec 15, 2020 6:08 pm Hey guys,
I just bought a BH16NS55 with 1.03 firmware. What exactly are my options for UHD support?
I think this is all very confusing.
In the pack there are following options:
- BH16NS55 1.05
- WH16NS60 1.03
- (old) BH16NS55 1.03
- (old) BH16NS55 1.04
- (old) WH16NS60 1.01
- (old) WH16NS60 1.02
In the first post there is the WH16NS60 1.02 mentioned as recommended. But there are new versions?
Re: Ultimate UHD Drives Guide Updated 2020
Do so if you only use Makemkv. Otherwise cross-flash it later to ASUS BW-16D1HT 3.10MK. Works with AnyDVD and the monkey. WH16NS60 will only work with Makemkv.
Do exactly as the guide says it is up-to-date flash directly to WH16NS60 1.02mk from the all you need firmware packmatterno wrote: Tue Dec 15, 2020 6:08 pm Hey guys,
- BH16NS55 1.05
- WH16NS60 1.03
@Billycar11
Hi Billy,
I tried emailing you to purchase a disc drive, but it said your email was unreachable.
The email address I sent it to was Billycar5924@gmail.com.
-Matt
Hi Billy,
-Matt
i have bu40n(firmware BW42).
i try flash de 1.00 firware and mk 1.04 firmware. flash it
bachelorbob
Are you asking what to do or announcing success at what you did?wwwhana wrote: Fri Dec 18, 2020 11:29 am i have bu40n(firmware BW42).
Must have been when Gmail was down try resending itcugrz wrote: Wed Dec 16, 2020 7:41 pm @Billycar11
Hi Billy,
-Matt
"Command produced error code 0x8f05c103"
Just getting started on the idea of ripping my video discs. I bought a new LG BH16NS55 which worked fine in Windows out of the box. Details:
Following the instructions (I believe correctly) in this thread I installed the SDFtool Flasher. I used this to take a backup of my drive firmware. That created a tar file in the Firmware_Dumps subfolder as expected.
I then tried to flash the firmware file from the "The all you need firmware pack" using the "enc" (encoded) option.
I have tried to run the firmware patch 5 times now. 3 times it stopped right at the beginning with the error shown above-
Twice it appeared to run to completion. However when I run MakeMKV again it still shows the original firmware version (1.04). Just in case, I rebooted the PC after one of the apparrently good writes, but the firmware on the drive still reports as being the BH16NS55 v1.04, so it looks like the new firmware has not stuck.
Firstly, am I doing something obvious wrong? and secondly, are repeated attempts to overwrite the firmware increasing the risk of bricking my brand new drive?
I used the SDFTool because I wanted to back up the existing formware. As I understand it this uses the command-line firmware patcher underneath the GUI, but would I get different results from the command line patch tool?
Product: BD-RE BH16NS55
Revision: 1.04
Serial number: KLGK2PD4225
Firmware date: 2119-01-04 13:42
Highest AACS version: 23
Harware support: Yes
Firmware support: No
Firmware version: 1.04
Unrestricted read speed: Possible (with patched firmware)I then tried to flash the firmware file
HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.binI have tried to run the firmware patch 5 times now. 3 times it stopped right at the beginning with the error shown above-
Command produced error code 0x8f05c103Firstly, am I doing something obvious wrong? and secondly, are repeated attempts to overwrite the firmware increasing the risk of bricking my brand new drive?
1.04 is not encrypted so don't tick the 'enc' box and try again.
Gaah <slaps forehead...> I was convinced I'd read that the drives currently shipping all had encrypted firmware.Mr_Orange wrote: Sun Dec 20, 2020 11:31 pm 1.04 is not encrypted so don't tick the 'enc' box and try again.
Just tried it, loks good. Thanks
only use the enc command or check box if your firmware is listed as encrypted in the first post the makemkv developer updates that for me.
ahhhh, I was so confused about enc firmware or not, but I got it working (first try)! Thanks to Billycar11 and MartyMcNuts!
(background/summary/tldr: bought new OEM LG drive and got it flashed without problems)
Only bug encountered was with the SDFtool Flasher, I had an older version of MakeMKV so the SDFtool Flasher found the MakeMKV folder, but threw an exception and wouldn't start. I upgraded to latest version of MakeMKV and the SDFtool Flasher was able to start. (there was no sdftool.exe in my MakeMKV program files).
Now, my point of confusion. First, I'm using a brand new LG WH16NS60 (MakeMKV says "Manufacturer: HL-DT-ST Product: BD-RE WH16NS60"). The guide says
So I thought I had to start by downgrading to LG WH16NS60 1.02MK, but maybe not? It does says **and there is no MK version**? So the first flash off of factory firmware isn't really clear to me. Can I jump straight to 1.02 MK or do I need to start with 1.03 MK? I'm not sure. Here's what I *did* do:
Download the MK firmware pack. Then I used SDFTool Flasher with firmware
HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin -- with "enc" box **checked**
Then I downloaded the "all you need firmware pack" and used SDFTool Flasher with firmware
HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin -- with "enc" box clear (not checked)
Previously MakeMKV said LibreDrive status: with firmware upgrade, now it says:
The newer OEM firmwares cannot be flashed easily due to the additional downgrade checks implemented by the drive/firmware manufacturer. If your drive has one of these firmwares, and there is no MK version of the same firmware/drive model or higher number, you will have to sidegrade to Asus 3.10MK (for compatible ASUS 5.25 drives ONLY) or (LG WH16NS60 1.02MK for compatible LG 5.25) or (BU40N 1.03MK LG Slim drives ONLY) respectively. (Note: MK firmware is available for firmware versions mentioned above.)
Everything seems to be working now, I'm testing with The Big Lebowski Limited Edition. Thanks for the great community resource everyone.Drive Information
Revision: 1.02
Serial number: ----------------
Firmware version: 1.02
Re: Ultimate UHD Drives Flashing Guide Updated 2020
Thank you for the guide! I'll update after I get a few movies ripped. For now I both a wh16ns60, and 40. I have both on 1.02 running on a VM Ubuntu, running on Proxmox. Not bad for a complete quadruped with ALS. Right?
Re: Ultimate UHD Drives Guide Updated 2019
Hi, I've been trying for hours now to get my LG CH12NS40 to play 4K Blu-rays but I can't get it to work. Have you guys found a solution for 4K on this player? What firmware do I need to flash....wag12wag12 wrote: Tue Feb 11, 2020 11:49 amHi, I also have a CH12NS40 , where can I find information on how to do this patch to enable 4K read?
If anyone can help me, I would be very grateful.
bobby121418
I am looking to get a slim drive to flash myself. I was going to get LG BP60NB10 but it is now out of stock. Which other would the experts recommend?
