LOTR:TTT Failed to open disc / The volume key is unknown for this disc - video can't be decrypted
Daxelinho
#1 Post by Daxelinho » Wed Dec 16, 2020 9:34 pm
today the newly released "Lord of the Rings" Extended 4K bluray , German release, arrived and I promptly started to rip them.
"Fellowship of the Ring" worked like a charm. But with the first disc of "The Two Towers" the problems began.
The disc information for TTT was correctly displayed. But it couldn't be loaded. MakeMKV put out the following log:
Debug log started at Wed Dec 16 21:16:15 2020 , written by MakeMKV v1.15.4 win(x64-release)
001005:0000 MakeMKV v1.15.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\***/MakeMKV_log.txt
WinCdArb=v1.0.0_tiny win(x64-release)
DEBUG: Code 3 at l36L!t.ju1-I5hQj<x_&C<|l:29395310
SDF v07d: ASUS_BW-16D1HT_3.10_211901041014_KLHK76F5343
001011:0000 Using LibreDrive mode (v06.2 id=0FA242DD4D0B)
DEBUG: Code 2147483648 at )MlMsgQtKhB02k"5:121264786
003332:0000 Saved AACS dump file as file://O:/MakeMKV/MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_(EXT_)_PT_1_2F1F.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at \hDnJ)j9w B>P Qk:29396069
001003:0020 DEBUG: Code 0 at \hDnJ)j9w B>P Qk:29395149
Can I do anything about this issue? I've stumbled across a similar error with Zombieland which couldn't be resolved by the team (or rather, it was out of the team's hands).
Re: LOTR:TTT Failed to open disc / The volume key is unknown for this disc - video can't be decrypted
#2 Post by d00zah » Wed Dec 16, 2020 9:59 pm
UHD FAQ
Refer to section Hashed Keys > MakeMKV says that "the volume key is unknown for this disc"?
Daxelinho
#3 Post by Daxelinho » Wed Dec 16, 2020 10:35 pm
Thanks, I just sent them. At least it seems like an issue that can easily be dealt with. :D
Daxelinho
#4 Post by Daxelinho » Fri Dec 18, 2020 8:47 pm
To be sure because it is not working yet: The file in question is named
"MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_(EXT_)_PT_1_2F1F.tgz."
This is the right file, is it? I've mailed this to svq@makemkv.com
Don't want to stress anyone, just want to make sure I've done everything correctly because it's my first time encountering this error.
#5 Post by dcoke22 » Sat Dec 19, 2020 4:37 am
Yep, you've done it right. That's the correct file and the correct email address.
Daxelinho
#6 Post by Daxelinho » Sat Dec 19, 2020 11:36 pm
Thanks, then I just have to wait. I guess there are lots of other things much more important than MakeMKV right now over the holidays. In the end the team does their best so waiting a few days should be no problem.
