Android support for the Lib files?
linuxares
Post by linuxares »
Hi!
I got the most stupid idea, I got an Nvidia Shield TV Pro. It use USB3 so it should in theory without issues be able to playback Blu-rays.
I got an Libredrive since before, I use it to rip my blurays to be able to watch on Kodi.
But I used to have HTPC before with Windows and Xreveal before I replaced it with MakeMKV.
MakeMKV just makes it better for sure!
I wonder if it's possible the Lib files would be able to be used on Android? It's a Linux kernel in the bottom but not so sure how plausible it is in the OS after is said and done.
Anyone tried this odd endeavor before?
Re: Android support for the Lib files?
Right now, MakeMKV doesn't run on ARM devices, so no, it won't work. But, that's "for now".
