error message question
craig
Post by craig »
I have used makemkv to burn blu-rays with no problem for a month. I purchased a registration code and the first 2 movies I tried I got errors, could be coincidence. Does anyone know what this problem is? Thanks.
MakeMKV v1.6.3 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5630A 1AHN" opened in OS access mode.
Optical drive "BD-ROM ASUS SBC-06D1S-U A201" opened in OS access mode.
Hit OS X IOSCSIMultimediaCommands bug, used type 0 workaround, see http://www.makemkv.com/osxbd/ for details.
File 00000.mpls was added as title #0
File 00006.mpls was added as title #1
File 00013.mpls was added as title #2
File 00026.mpls was added as title #3
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00008.m2ts was added as title #4
Title #00009.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00013.m2ts was added as title #5
File 00014.m2ts was added as title #6
File 00015.m2ts was added as title #7
File 00016.m2ts was added as title #8
File 00018.m2ts was added as title #9
Title #00019.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/xxxxxxxx/Movies
Title 0 skipped
0 titles saved
Saving 1 titles into directory /Users/xxxxxxxxx/Movies
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '19006617600'
Failed to save title 0 to file /Users/xxxxxxxxx/Movies/title00.mkv
0 titles saved, 1 failed
Re: error message question
Post by mike admin »
Most likely it's a damaged disc. To confirm try copying the file in question in finder and see if it fails.
