Issue with WH14NS40
Brianebrown1979
Issue with WH14NS40
Post by Brianebrown1979 » Fri Dec 18, 2020 7:13 pm
Hello, I updated my LG Drive WH14NS40 to firmware patch 1.05 today, but now it won't recognize any discs. Would anyone be able to assist me in getting this back up an running? I used firmware HL-DT-ST-BD-RE_WH14NS40-NS50-1.05-NM00900-212005061444.
WH14NS40 image.JPG (84.45 KiB) Viewed 14331 times
Re: Issue with WH14NS40
Post by Coopervid » Fri Dec 18, 2020 7:52 pm
Looks fine. Did you reboot your PC?
st4evr
Post by st4evr » Fri Dec 18, 2020 8:34 pm
How long ago (what year?) was this drive originally purchased?
Can you post a picture of the physical label that is on the drive?
Brianebrown1979
Post by Brianebrown1979 » Fri Dec 18, 2020 9:18 pm
Yes, I rebooted the drive. The only issue is that it keeps showing "No disc" even though I have a DVD or Blu-Ray in the drive.
I would have to take the drive out of the tower to get an image of the drive, I bought it a while ago, probably close to the release date (so 8 years ago).
Post by Billycar11 » Fri Dec 18, 2020 9:34 pm
Brianebrown1979 wrote: Fri Dec 18, 2020 9:18 pm I bought it a while ago, probably close to the release date (so 8 years ago).
Well there is your problem I guess you dident read the uhd guide that says 2015+ and mt1959.
You should be able to recover it with sdf tool just select recovery and old ns40 fw
Brianebrown1979
Post by Brianebrown1979 » Fri Dec 18, 2020 10:41 pm
Yup didn't read it all the way through, that's what I get for rushing through things. Thank you!!
