problem is that player-led LLDV is often less accurate than tv-led full STD DVManixx2020beyound wrote: ↑Thu Dec 17, 2020 10:57 pmThis is an interesting read
According to this article dv-rgb8 is the old dv & LLDV is now mandatory on all doblyvision regular dv is not required
LLDV has it own profile as well.
https://www.google.com/amp/s/blog.semte ... s_amp=true
Blame Sony.pete19 wrote: ↑Fri Dec 18, 2020 12:26 amproblem is that player-led LLDV is often less accurate than tv-led full STD DVManixx2020beyound wrote: ↑Thu Dec 17, 2020 10:57 pmThis is an interesting read
Dolby set out with good intentions and now hardware manufacturers are calling the shots.
the problem is the approach, in player-led LLDV the TV/sink must pass over all calibration parameters and current settings/values (whatever can be passed via HDMI, EDID etc), and based off that the player must decode the Dolby stream accordingly.DaMacFunkin wrote: ↑Fri Dec 18, 2020 9:05 amBlame Sony.
This will most likely never be as accurate as decoding full tv-led DV in the TV hardware itself with all of those parameters plus additional data that cannot or wasn't transmitted...
in a perfect world it is, but practical tests have often shown the difference
So the dolby vision files created using the method in the OP can't be played using the tv internal media player anymore? What is the alternative?Wanderlust3K wrote: ↑Wed Dec 16, 2020 3:32 pmCan confirm that, no more Dual track/dual layer mp4 files with CX.
I bought the BluRay Player LG UBK90 for 138€. Now its 131,60 €.
It can play DV Dual Layer mp4.
Totally agree, had this argument with many a LLDV evangelist, with the Oppo clone you can switch between Tv led and player led, there’s is a difference, on some content it is very noticeable.pete19 wrote: ↑Fri Dec 18, 2020 9:38 amthe problem is the approach, in player-led LLDV the TV/sink must pass over all calibration parameters and current settings/values (whatever can be passed via HDMI, EDID etc), and based off that the player must decode the Dolby stream accordingly.DaMacFunkin wrote: ↑Fri Dec 18, 2020 9:05 amBlame Sony.
Is it a paid article by Dolby?Manixx2020beyound wrote: ↑Thu Dec 17, 2020 10:57 pmThis is an interesting read
The guy only forgot to mention that due to LLDV "sinks" switch off most of their image processing, resulting in visible shittier image quality
there's been a lot of discussion that dolby vision causes problems for bluray authoring (bitrate limitations that vary based on potions of the disc when one gets into double and triple layers) and there's been much more uptake for it on streaming where it's easier to implement as constant bitrate limit). It could be that dolby is transitioning away from bluray based dv and putting their eggs more in the streaming basket.
Eventually, Dolby Vision and other media companies will move away from physical media. We are minority, we have to accept it. Future is with streaming. The quality gap is very narrow and the convenience of streaming it's a winner for me. I am sure with better internet speeds, we will have the option to stream lossless auido in the future.
I agree with the fact that sooner or later physical media will go (although dvds are still around). But no way is streaming quality gap narrow. There’s a massive difference in bitrate.
Unfortunately it will have nothing to do with internet speeds, streaming companies will not want to store lossless/high bitrate content, no matter how cheap or doable it is - it just means it’s even more profitable to store the current bitrate starved versions.
Even just lossless audio is unlikely to happen, the next step will be the still lossy AC4.
For anyone with an LG CX, the new firmware update purportedly allows profile 7 files to be played in the internal player. I'm unable to test this myself for a few weeks since I'm staying away from home. Previously the LG CX could only play 8.1 files. Good news if true because, unlike 8.1, profile 7 is dual layer and I believe supports the 12 bit colour in FEL titles. It could also make it far easier to play DV files if we can just rip them (albiet there still needs to be an audio conversion) rather than also having to do the Yosupe 8.1.bat conversion.
quick question i wanna ask
what profiles should we use or does this depend on the situtation
like whats the diffrence between profile 7 and profile 8.1?
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
I noticed following yuescopes guide with ffmpeg
that the ffmpeg is rather fast converting the file to bl and el
is this because i'm using the wrong command?
it also creates only very small files (1GB) with a super low bitrate
is this something to do with my m2ts file?
i follow the first guide on his FEL TO MEL
movie i tested with was mission impossible fallout and 1917
how do i know if these movies are fel titles or mel titles?
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Maybe if you looked at my post directly above yours you might get some answers...rosavanwinkle wrote: ↑Sun Dec 20, 2020 1:54 amquick question i wanna ask
If you google Dolby vision profiles it is easy to find the Dolby paper which lays out the differences, albiet somewhat vaguely.
7 theoretically allows for 12 bit colour with supported titles, while 8.1 does not. However you might find that profile 7 MEL (10 bit colour) works while profile 7 FEL (12 bit colour) does not. If neither works you might try 8.1. Outside of the 12 bit colour both 7 and 8.1 should present the same visually.
Your bio says NVIDIA Shield, I don't use that but there's plenty of talk of the Shield in this thread.
That's so awesome. I just started researching this because of the CX fixed dolby vision raised blacks.dapope wrote: ↑Sun Dec 20, 2020 12:22 amFor anyone with an LG CX, the new firmware update purportedly allows profile 7 files to be played in the internal player. I'm unable to test this myself for a few weeks since I'm staying away from home. Previously the LG CX could only play 8.1 files. Good news if true because, unlike 8.1, profile 7 is dual layer and I believe supports the 12 bit colour in FEL titles. It could also make it far easier to play DV files if we can just rip them (albiet there still needs to be an audio conversion) rather than also having to do the Yosupe 8.1.bat conversion.
I have just one question. I know that the LG Webos Plex can't play lossless atmos on dolby vision remux, but is it possible to play lossy atmos from blu-ray remux? My understanding is that if a blu-ray contains a TrueHD atmos track, that it also contains a lossy version as a fall-back. Is that correct? And can the CX play that?
Because i have a soundbar(even though its a pretty good one), and i think i would sacrifice lossless atmos for lossy if i can get dolby vision.
