Inherit name for first entry
hook77
Post by hook77 »
today I recognize a bug where the title is not inherited to the first track name when the title is edited.
I know in previous version this worked as a charm (but cant remember since when it is broken)
Tried both 1.15.3 and 1.15.4.
I did not check if this is a Linux only issue, most likely it is a common thing.
Best, Hook
Re: Inherit name for first entry
MakeMKV will take what you put in the disk name and copy it to all unaltered title names. If you've changed one, it will not have the disk name title copied to it.
I do not think it is a bug, and I've used it to my advantage for years. Change the disk title, let it copy to all titles, then alter the titles to add the episode number. If I hit a "roll-over point" (episode 09 to 10), I go back up and edit the disk name, and it's copied to the unchanged titles.
