agneva
Post by agneva » Tue Dec 15, 2020 5:45 pm
this makes DVDFab with DV SL, can´t be set.
the MEL movies can also be re-encoded. Thank's to @quietvoid rpu extractor.
did you try with profile 8 ?
How can I create Profile 8 with reencoded FEL ?
Of course you can´t see any difference between a empty (M)EL and no EL.
Private Ryan´s FEL is pumping when you look only the FEL on Media Player Classic, looks very strange :lol:
The quality is bad + brightness pumping if you watch it without FEL. The FEL is necassary.
I tried to watch, but after 20min i switched to HDR10.
Today I could convince myself from the real DV Version of Ryan :arrow: its very nice.
calibra3
Post by calibra3 » Tue Dec 15, 2020 5:58 pm
Roberespa wrote:
Sun Dec 13, 2020 5:01 pm
* Tutorial on how to convert an .iso movie with HDR10 and Dolby Vision to .m2ts *
MakeMKV
tsMuxeR:
ffmpeg
Use tsMuxeR and open "BL_EL_RPU.hevc" To put the audios and subtitles that you mount in a virtual unit, the FULL-UHD Dolby Vision.iso adds 00073.m2ts unchecks the two video tracks (only adds the audio tracks and subtitles) or previously with tsMuxeR you make a DEMUX to simply add the audio tracks and subtitles to the "BL_EL_RPU.hevc" and give it to create a .ts or .m2ts video file (I recommend .m2ts because it is the purest).
and ready.
Hello from Spain Rober.
Please can you tell me how to do if I have two disc for example of hobbx or LOTR???
How I can merge the two disk to do your tutorial?
Post by RESET_9999 » Tue Dec 15, 2020 6:05 pm
you have to use yusesope tools or demux your dvdfab mp4 file and then remux with the mp4muxer to profile 8.
https://www.makemkv.com/forum/viewtopic ... 970#p96282
you can't ''properly'' re-encode and preserve FEL.
You could re-encode to mel with @quietvoid rpu extractor + x265.exe
https://github.com/quietvoid/dovi_tool/ ... /0.1.0-fix
Post by shawnc22 » Tue Dec 15, 2020 7:07 pm
agneva wrote:
Tue Dec 15, 2020 4:41 pm
shawnc22 wrote:
Tue Dec 15, 2020 3:15 pm
Unless something changed, I believe DVDFAB strips away the EL in their DV MP4 conversion. You can verify this with mediainfo if you see only one video track that's labeled BL+RPU.
you can set it in dvdfap:
if you choose EL+RPU than you get it:
i just tested it with Saving Private Ryan, it has an FEL.
If I choose DV Single Layer for playback on my LG CX9 i get brightness pumping.
If I choose DV Dual Layer, the CX9 doesn´t play, but the LG UBK90 plays it correct.
I think all movies with empty EL (MEL) can be ripped in DV SL.
https://forum.blu-ray.com/showthread.ph ... st12116287
Ah that's interesting. I didn't know that dvdfab can now produce the same results as mp4muxer and that the ubk90 can actually play these dual track files. Wonder if it can do the same with TS files
agneva
Post by agneva » Tue Dec 15, 2020 9:38 pm
Didn't try .TS yet, just m2ts.
Do you think ts could work with DV DL too?
Post by shawnc22 » Tue Dec 15, 2020 10:04 pm
Not sure if anyone's tested, but the x700 can. If the ubk90 can as well, then that potentially adds another device to the list that can play real FEL DV w/lossless audio.
agneva
Post by agneva » Wed Dec 16, 2020 6:36 am
Do you have a small test *.ts for me ? I would like to test it on UBK90.
edit: I tried myself a *.ts - its been played in HDR :(
Post by Manixx2020beyound » Wed Dec 16, 2020 2:33 pm
pete19 wrote:
Tue Dec 15, 2020 1:08 pm
thanks. so how do you convert the png file to SDR ? ffmpeg as well or madvr ? can you share your process ?
I use madVR because I consider it the best HDR to SDR tone mapping but it probably can be done with ffmpeg. I don't know how though.
So just open the png in MPC-BE/HC/madVR. it needs ''transfer=hdr'' in the filename.
Wanderlust3K
Post by Wanderlust3K » Wed Dec 16, 2020 3:32 pm
quietvoid wrote:
Fri Dec 11, 2020 9:43 pm
The CX is rumored to have lost dual track mp4 support.
Can confirm that, no more Dual track/dual layer mp4 files with CX.
LG's dynamic tonemapping is garbage (at least on the C8).
Ouch, i thougth the lack of Dolby Vision support could be offset with Dynamic Tonemmaping and it seems its still garbage on CX according to HDTVTest:
https://www.youtube.com/watch?v=VGO38f1EoYE
Wanderlust3K
Post by Wanderlust3K » Wed Dec 16, 2020 3:39 pm
Roberespa wrote:
Sat Dec 12, 2020 4:24 pm
Maikel777 wrote:
Sat Dec 12, 2020 3:55 pm
I also have a TV
LG OLED55B6V.
For the movie The Lord of the Rings.
Which Dolby Vision profile is best suited for my TV? 5, 7, 8 or 8.1
Thanks in advance.
-Hello:
I have found this information:
Profile 5 single layer with exclusive support for Dolby Vision
Single layer 8.1 profile with HDR10 + Dolby Vision compatibility
Profile 8.2 single layer with SDR compatibility
From what i can read Profile 8.1 would be the best as it has HDR10 + Dolby Vision.
But I am a newbie at this.
If someone clears it up.
I would be very grateful, it is also of my interest since I have the same television.
B6 are (or were if firmaware did not change that ) play Dual track/dual layer DV MP4 files, so he betters keeps just using the Dolby muxer tool, profile 7, and get a Dual track/dual layer MP4 DV file.
Post by RESET_9999 » Wed Dec 16, 2020 5:08 pm
''transfer=hdr'' is only to tell madVR: hey this file is in PQ.
it has nothing to do with ffmpeg.
pete19
Post by pete19 » Thu Dec 17, 2020 3:58 am
is this parameter for ffmpeg or madvr ?
Post by RESET_9999 » Thu Dec 17, 2020 4:06 pm
I just answered that one post above.. that parameter is only for madVR...
if you want SDR screenshots, no need of FFmpeg. just tone map your HDR video straight in madvr.
Post by Manixx2020beyound » Thu Dec 17, 2020 10:57 pm
This is an interesting read
According to this article dv-rgb8 is the old dv & LLDV is now mandatory on all doblyvision regular dv is not required
LLDV has it own profile as well.
https://www.google.com/amp/s/blog.semte ... s_amp=true
pete19
Post by pete19 » Fri Dec 18, 2020 12:25 am
yeah, your post was a bit unclear, but this one cleared it up. Thanks. :D
I gotta dig into madvr, still no idea how to display an image with it... :mrgreen:
