"automatic sdf downloading is disabled or failed" while decrypting
Re: "automatic sdf downloading is disabled or failed" while decrypting
#151 Post by d00zah » Thu May 21, 2020 2:58 pm
coldfire05 wrote: Thu May 21, 2020 2:45 pm Pardon my ignorance, but where is the "MakeMKV data directory" located in LinuxMint?
Thanks in advance,
coldfire05
What path is defined on the 'General' preferences tab?
bludvddsl
#152 Post by bludvddsl » Wed Dec 16, 2020 1:45 am
Getting the "Automatic HK downloading is disabled or failed" error with 1.15.4
Option for MakeMKV to connect to internet is enabled
Tried changing DNS to Google, no luck
Disabled firewall, and antivirus, no luck
I downloaded the sdf.bin and placed it in the data directory, but the file is not getting ingested by MakeMKV on launch. Can anyone please advise why the sdf.bin is not imported? The modify date on _private_data.tar is not getting updated
#153 Post by Woodstock » Sat Dec 19, 2020 3:46 pm
Only REALLY OLD versions or an old (as in months old) SDF file would mention the .tk domain.
hkdata.fairuse.org is the current host name, and it should resolve to an IP that is in the Russian Federation. A number of servers will not resolve any domain in fairuse.org (cloudflare being one of them, even though they are used for the forum), and any geoblock you may have on the RF could get in the way.
a22d93
#154 Post by a22d93 » Sat Dec 19, 2020 11:23 pm
Other threads have fairuse.org as the current location for the keys and appear to have been able to access it recently. Is the server down right now for anyone else? I just discovered this community and maybe its just bad luck the server happens to be down now. I am backing up a normal BD now so I know that works, but UHD has not been so lucky.
#155 Post by Woodstock » Sun Dec 20, 2020 12:05 am
It is possible that hkdata.fairuse.org is off-line right now. It resolves to 91.224.23.225 right now, and I'm showing a 10% packet loss on pings to it. Chrome says the connection is being refused.
rebelyell91
#156 Post by rebelyell91 » Sun Dec 20, 2020 12:08 am
I'm very new to all of this but I was trying to curl http://hkdata.fairuse.org/ and I'm getting "connection refused" immediately. MakeMKV output is "Automatic HK downloading is disabled or failed." and I have white-listed it in Windows firewall and DNS works (resolves to 91.224.23.225). I suspect the server is down?
rrj_ok
#157 Post by rrj_ok » Sun Dec 20, 2020 2:57 am
Does anyone have a recently updated "_private_data.tar" file they could kindly post up? I am having the same issue as others where I get a failure with downloading HK. Thanks!
Abbietmp
#158 Post by Abbietmp » Sun Dec 20, 2020 3:41 am
Getting the "Automatic HK downloading is disabled or failed" error as well.
I am able to resolve hkdata.fairuse.org but I am unable to get a response from the http server.
I checked a few services that do DNS traces and/or check access from globally distributed nodes to verify which regions can or cannot access.
The domain appears to be offline across the board.
#159 Post by Billycar11 » Sun Dec 20, 2020 5:32 am
ok everyone you can have mine again i updated my old post
https://www.makemkv.com/forum/viewtopic ... 114#p80114
ksalno
#160 Post by ksalno » Sun Dec 20, 2020 6:09 pm
Working now for me in US.
bbraskey67
#161 Post by bbraskey67 » Thu Jan 21, 2021 11:36 pm
Getting the "Automatic HK downloading is disabled or failed" error today when trying to rip the new 4K version of 2012. Haven't changed any network settings since the last download. Using Google DNS.
MrEWhite
#162 Post by MrEWhite » Fri Jan 22, 2021 2:05 am
bbraskey67 wrote: Thu Jan 21, 2021 11:36 pm Getting the "Automatic HK downloading is disabled or failed" error today when trying to rip the new 4K version of 2012. Haven't changed any network settings since the last download. Using Google DNS.
Same issue here, different disc though. I've had no issues with this in the past.
hamsterdance
#163 Post by hamsterdance » Fri Jan 22, 2021 10:15 am
If you navigate (using a web browser) to hkdata.fairuse.org, you'll see a message saying "hosting disabled" (in Russian). This means that the issue is not on your side or mine - it's on the host that holds the HK data. There's nothing we can do about it except wait for it to be resolved.
pyromike25
#164 Post by pyromike25 » Fri Jan 22, 2021 1:38 pm
Billycar11 wrote: Thu Oct 24, 2019 9:08 pm This is a one time kinda thing i dont know if these work on mac windows linux but here is the latest windows version as of the day of this post.
It has updated sdf and hashedkeys in this
delete your privatedata.tar and replace it with this one
https://drive.google.com/file/d/1SSo_O- ... sp=sharing updated 12/20/2020
Billycar11 wrote: Sun Dec 20, 2020 5:32 am ok everyone you can have mine again i updated my old post
Was having this issue with Avengers: End Game 4K blu ray. Thanks Billycar11 for this privatedata.tar file. I dropped it in and it worked just perfect after that.
bbraskey67
#165 Post by bbraskey67 » Fri Jan 22, 2021 5:52 pm
pyromike25 wrote: Fri Jan 22, 2021 1:38 pm
Worked for me too. Thanks Billycar11 for the file and to pyromike25 for posting the link to the file!
