Failure Ripping Terminator 3 Blu-Ray
redray2323
#1 Post by redray2323 » Fri Jan 07, 2011 7:32 pm
Any help will be much appreciated! I have gone through countless blu-rays, but this title is the first and only one that indicates that the title failed to save. (I use the Mac version 1.6.3 and have a Plextor Blu-ray drive).
I tried installing an older version of MakeMKV on another machine (1.6.2) but, wasn't able to since it would crash out before I could enter my registration code.
Thanks in advance and please let me know if I can provide any additional information.
setarip_old
Re: Failure Ripping Terminator 3 Blu-Ray
#2 Post by setarip_old » Fri Jan 07, 2011 8:42 pm
Hi!
Submit a Debug file...
redray2323
#3 Post by redray2323 » Fri Jan 07, 2011 9:26 pm
Debug log started at Fri Jan 7 20:55:22 2011 , written by MakeMKV v1.6.3 darwin(x86-release)
001003:0020 DEBUG: Code 6094848 at 'u<[]5WgK1,d|&;Fk>+An_l:213130007
001005:0000 MakeMKV v1.6.3 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Omid/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL HL-DT-ST DVDRW GA11N KA16" opened in OS access mode.
001003:0020 DEBUG: Code 3758097095 at wx2,&iBo%7U59,XhVM:p|jS?sQw;:121263061
002010:0000 Optical drive "BD-ROM PLEXTOR BD-ROM PX-B120U 1.06" opened in OS access mode.
001003:0020 DEBUG: Code 0 at wx2,&iBo%7U59,XhVM:p|jS?sQw;:213132100
DISCID=4DF463A2D9E0940EE7C10AAAC3EA53FE1E08510D
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00002.mpls was added as title #1
003025:0000 Title #00000.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00004.m2ts was added as title #2
003307:0000 File 00005.m2ts was added as title #3
003307:0000 File 00006.m2ts was added as title #4
003025:0000 Title #00007.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00008.m2ts was added as title #5
003307:0000 File 00009.m2ts was added as title #6
003307:0000 File 00010.m2ts was added as title #7
003307:0000 File 00011.m2ts was added as title #8
003025:0000 Title #00012.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Users/Omid/Movies/Work in progress
002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
001003:0020 DEBUG: Code 1 at a+>Es62@;/*QoW6p@9h:29400232
001003:0020 DEBUG: Code 0 at a+>Es62@;/*QoW6p@9h:121265200
FS ID=V_MS/VFW/FOURCC C=1
TI=ZeNpjZGBgKO2zZ4CDZwyMvkCq4QkDIzMDYdDAzsBgwYKgDUoZGF4CNTIhqQEAj3kG+Q==
C_00000=ZeNpreCY7j5mdgeE/FDBAwX80wAwUY2JABaxgkpG3FgC0Gxqp
001003:0020 DEBUG: Code 0 at db(U'_iL&izym*Rbn#V*O:29397449
005003:0000 Failed to save title 0 to file /Users/Omid/Movies/Work in progress/title00.mkv
005004:0080 0 titles saved, 1 failed
setarip_old
#4 Post by setarip_old » Sat Jan 08, 2011 12:35 am
I believe this is indicative of either a dirty or damaged disc...
redray2323
#5 Post by redray2323 » Sat Jan 08, 2011 2:09 am
Hmm, disc looks fine but will get a replacement disc and see if I have the same problem. First time this has ever happened like this. I have had messed up discs that just clocked for a very long time and I had to abort. This is a bit of a different scenario. I'll report when I get a new disc. Thanks.
redray2323
#6 Post by redray2323 » Mon Jan 10, 2011 10:52 pm
Debug log started at Mon Jan 10 22:08:54 2011 , written by MakeMKV v1.6.3 darwin(x86-release)
TI=ZeNpjZGBgKO2zZ4ABh8ZGRl8gLdDQyMjMQBg0sDMwWLAgaINSBoaXQI1MSGoAk8oHAg==
redray2323
#7 Post by redray2323 » Mon Jan 10, 2011 10:53 pm
New disc, same issue, leading me to believe it is MakeMKV, not the disc. Granted I have tried countless other titles and they have all worked flawlessly. Any guidance would be appreciated!
Marc_G
#8 Post by Marc_G » Thu Jan 13, 2011 2:35 am
FWIW, I had no trouble using MakeMKV approximately 1.60 ripping US T3 [commercial release BD] on a Win7 x64 system with a Lite-On drive. Probably this doesn't help, but it's a data point...
setarip_old
#9 Post by setarip_old » Thu Jan 13, 2011 2:41 am
What is the title and region of your original, commercial Blu-ray disc?
#10 Post by mike admin » Mon Jan 17, 2011 11:07 am
Looks like video stream is corrupted. What happens if you do a full disc backup with MakeMKV?
goingbust
#11 Post by goingbust » Wed Jan 19, 2011 5:17 am
I get the same thing. One interesting thing is it rips all files except title01.mkv fine. Here are the sizes for the others:
14,643,727,788 title01.mkv
506,211,940 title02.mkv
151,006,602 title03.mkv
83,753,179 title04.mkv
116,717,883 title05.mkv
256,114,124 title06.mkv
348,043,724 title07.mkv
93,378,750 title08.mkv
The disc is pristine. I have tried to rip title01.mkv alone twice after cleaning the disc and both times it runs to completion and then gives an error message right at the end. It doesn't seem to be a defective disc - I have had defective discs before and what happens is it pauses and retries the disc somewhere in the middle and then craps out after spinning its wheels for a bit. With this one, it runs to completion without errors until "Remaining" is 0:00:00 and then it throws the error. Here is the log:
Debug log started at Wed Jan 19 04:52:32 2011 , written by MakeMKV v1.6.2 win(x64-release)
001005:0000 MakeMKV v1.6.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Joe/MakeMKV_log.txt
005075:0000 The new version 1.6.3 is available for download at http://www.makemkv.com/download
005014:0000 Saving 1 titles into directory G:/Video/TERMINATOR_3
001003:0020 DEBUG: Code 1 at 4,O:||lWA!BpRtH9bS\:29400232
001003:0020 DEBUG: Code 0 at 4,O:||lWA!BpRtH9bS\:121265200
TI=ZeNpjZICADdtsHRgZMMEEdxcw7QtTN7lCGUQzMxAGDewMDBYsCNqglIHhJVAjE5IaAEQtCEg=
C_00000=ZeNpreCY7j5mdgeE/FDCggf9ogBkoxsSACVjhLEbeWgDWJhqp
001003:0020 DEBUG: Code 0 at se#Wjk$|<_4^GI!MuC-~~:29397449
005003:0000 Failed to save title 0 to file G:/Video/TERMINATOR_3/title00.mkv
Application exited at Wed Jan 19 05:12:14 2011
I will try the full disc backup as you suggest now...
goingbust
#12 Post by goingbust » Wed Jan 19, 2011 5:55 am
I did the full backup. No errors. I guess the log reflects that:
Debug log started at Wed Jan 19 05:14:01 2011 , written by MakeMKV v1.6.2 win(x64-release)
005072:0000 Backing up disc into folder "G:/Video/backup/TERMINATOR_3"
005070:0080 Backup done
005081:0104 Backup done.
Application exited at Wed Jan 19 05:53:00 2011
The backup produced a file G:\video\backup\TERMINATOR_3\BDMV\STREAM\00001.m2ts that appears to be a full 1080p copy of the main film.
I wonder what the problem was? Anyway, this is good enough for me. Thanks for the suggestion, I had not tried a full backup before.
TBOlson
#13 Post by TBOlson » Sun Feb 27, 2011 6:07 pm
I'd like to revisit the Terminator 3 issue. Although the disk is readable (and can be backed up), it cannot be converted to MKV.
Attached is a log of trying to make an MKV from backup...
Opening files on harddrive at R:/Drive-M-Save/Work/backup/TERMINATOR_3/
Saving 1 titles into directory R:/Drive-M-Save/Work
Failed to save title 0 to file R:/Drive-M-Save/Work/title00.mkv
0 titles saved, 1 failed :?:
kevoone
#14 Post by kevoone » Sat Feb 11, 2012 5:33 pm
Terminator 3 rip Title 00 keeps failing before completion and won't produce a dump file. There doesn't appear to be a solution in this thread. Anyone have a suggestion?
Below is all the info I have:
MakeMKV v1.7.2 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/XXXXXX/MakeMKV_log.txt
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI v1.3 mode.
Optical drive "BD-RE PIONEER BD-RW BDR-206D 1.56" opened in DASPI v1.3 mode.
Title #00000.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/XXXXXX/Desktop
DEBUG: Code 1 at D>3rt?E{%9>iAT>>6dy:121269386
DEBUG: Code 0 at D>3rt?E{%9>iAT>>6dy:213133940
DEBUG: Code 0 at ZJ&V4Wr`DCv3JkHS#7(ls:29397955
Failed to save title 0 to file /Users/XXXXXX/Desktop/title00.mkv
Enjoying his day,
And a vun and a two..
iMac - Mac OS X 10.8.4
Processor 3.4 GHz Intel Core i7
Memory 32 GB 1600 MHz DDR3
LG Black 14X BD-R 4MB Cache Blu-ray WH14NS40
MKV 1.8.3
Handbrake Version 0.9.9 x86 64
MTR 4.2.9.1
Meta X Version 2.4.6
#15 Post by mike admin » Sun Feb 12, 2012 7:32 am
This is a sort of disc mastering error. The next version, 1.7.3 will handle this (and similarly broken discs). For now, unfortunately, there is no workaround.
