The Hobbit German Version
nochzunennen
Post by nochzunennen »
I have the new The Hobbit UHD German Version and will not work with makemkv.
I get the message "The volume key is unknown for this disc - video can't be decrypted".
I sent the dump to mike´s mail address.
MKB20_v76_THE_HOBBIT_AUJ_EXT_BF59.tgz
(193.81 KiB) Downloaded 609 times
nochzunennen
Re: The Hobbit German Version
Backup successful today
Thanks Mike!
aerxbosk
Post by aerxbosk »
i have "The Hobbit: An Unexpected Journey / Extendet Version" too, but i got the same message:
Here are the dump:
Thank you, and best regards
(194.31 KiB) Downloaded 642 times
Since it appears that MakeMKV generated the same file for your disk, unless you aren't able download the hash key file for some reason, you should be able to decode it.
