Trim MKV without reencode AND keeping subtitles?
kingmustard
Post by kingmustard » Sun Dec 13, 2020 10:52 pm
I have an MKV video file (AVC H.264 video stream, AAC LC SBR audio stream, SRT text stream).
When I trim it (to the nearest key frame) with MKV Cutter 20170625, I get a video file called "video_withoutSubs", with no text stream.
When I trim it (to the nearest key frame) with avidemux 2.7.6 (Copy / Mkv Muxer), I get a video file with no a text stream.
Anyone have any ideas?
Re: Trim MKV without reencode AND keeping subtitles?
Post by Woodstock » Mon Dec 14, 2020 1:30 am
Was the SRT file part of the original MKV, or what I call a "side load" file that players will grab for subtitles if found in the same directory?
kingmustard
Post by kingmustard » Tue Dec 15, 2020 10:07 am
It's part of the file/container.
Please see below:
General
Unique ID                                : 100823356021557008391632230726625601725 (0x4BD9DF3E609B847E0019AC3FF85728BD)
Complete name                            : C:\Users\kingm\Desktop\videofile1.mkv
File size                                : 531 MiB
Duration                                 : 12 min 24 s
Overall bit rate                         : 5 983 kb/s
Encoded date                             : UTC 2020-08-28 17:33:41
Writing application                      : mkvmerge v34.0.0 ('Sight and Seen') 64-bit
Writing library                          : libebml v1.3.7 + libmatroska v1.5.0
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 4 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate                                 : 5 917 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Frame rate                               : 29.970 (30000/1001) FPS
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.095
Stream size                              : 525 MiB (99%)
Audio
Format                                   : AAC LC SBR
Format/Info                              : Advanced Audio Codec Low Complexity with Spectral Band Replication
Commercial name                          : HE-AAC
Format settings                          : Explicit
Codec ID                                 : A_AAC-2
Bit rate                                 : 64.0 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Frame rate                               : 23.438 FPS (2048 SPF)
Stream size                              : 5.68 MiB (1%)
Text
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 11 min 15 s
Bit rate                                 : 82 b/s
Count of elements                        : 236
Stream size                              : 6.82 KiB (0%)
Post by Woodstock » Tue Dec 15, 2020 2:39 pm
Depending on where you trim the video, the timing in the SRT file could be slightly (or wildly) off.
It's possible to use mkvmerge to copy out the parts you want, but I'm not sure it would be as "clean" as doing it with an editor, where you can make sure there is a key frame at the start. I've tried this before with "all in one" files, and the key frames are as much as two seconds off from where the actual video split should be.
Chetwood
Post by Chetwood » Wed Dec 16, 2020 5:43 am
Please see attached screenshot.
In Mediainfo simply select View -> Text and you can paste it here. No need for screenshots.
kingmustard
Post by kingmustard » Fri Dec 18, 2020 12:35 pm
Fixed :)
