Psnjerry
Post by Psnjerry » Tue Dec 15, 2020 3:46 am
Psnjerry wrote: Tue Dec 15, 2020 2:41 am i use dvdfab to make the dolby vision movies and i heard that it produces a fake dolby vision
i have a sample i made and if someone can test it against the method everyone uses in this forum.
thats if you have back to the future part 1 lol
https://mega.nz/file/NYgknYSa#aiz7hO8WT ... rAas_crLgo
i figured out how you guys are doing it lol. so easy. guess ill be testing myself.
Psnjerry
Post by Psnjerry » Tue Dec 15, 2020 6:00 am
Psnjerry wrote: Tue Dec 15, 2020 3:46 am
i seem to get the same results when i use mp4muxer and dvdfab. using dvdfab to make one stream causes it to have crushed blacks. 2 video streams work
Post by shawnc22 » Tue Dec 15, 2020 6:34 am
Psnjerry wrote: Tue Dec 15, 2020 6:00 am
i seem to get the same results with yusesope tools and dvdfab when i make mp4 into a 2 stream to play on c9 default app, making a one stream gives you crushed blacks.
don't use yusecope's tools or dvdfab when making mp4s for c9 playback, use mp4muxer.
Psnjerry
Post by Psnjerry » Tue Dec 15, 2020 8:26 am
shawnc22 wrote: Tue Dec 15, 2020 6:34 am
i meant mp4muxer. it looks the same to me but why you say i shouldn't use dvdfab?
pete19
Post by pete19 » Tue Dec 15, 2020 1:08 pm
RESET_9999 wrote: Mon Dec 14, 2020 12:11 pm
pete19 wrote: Mon Dec 14, 2020 8:58 am
could you share the cmd to take a LLDV HDR screenshot via ffmpeg ?
by time in second:
ffmpeg.exe -ss 3200 -i X:\video.mkv -vframes 1 X:\transfer=hdr.png
by frame number:
ffmpeg.exe -i X:\video.mkv -vf select='eq(n\,6672)' -vframes 1 X:\transfer=hdr.png
thanks. so how do you convert the png file to SDR ? ffmpeg as well or madvr ? can you share your process ?
Post by RESET_9999 » Tue Dec 15, 2020 3:15 pm
pete19 wrote: Tue Dec 15, 2020 1:08 pm
I use madVR because I consider it the best HDR to SDR tone mapping but it probably can be done with ffmpeg. I don't know how though.
So just open the png in MPC-BE/HC/madVR. it needs ''transfer=hdr'' in the filename.
Post by shawnc22 » Tue Dec 15, 2020 3:15 pm
Psnjerry wrote: Tue Dec 15, 2020 8:26 am
Unless something changed, I believe DVDFAB strips away the EL in their DV MP4 conversion. You can verify this with mediainfo if you see only one video track that's labeled BL+RPU.
agneva
Post by agneva » Tue Dec 15, 2020 4:41 pm
shawnc22 wrote: Tue Dec 15, 2020 3:15 pm
you can set it in dvdfap:
if you choose EL+RPU than you get it:
i just tested it with Saving Private Ryan, it has an FEL.
If I choose DV Single Layer for playback on my LG CX9 i get brightness pumping.
If I choose DV Dual Layer, the CX9 doesn´t play, but the LG UBK90 plays it correct.
I think all movies with empty EL (MEL) can be ripped in DV SL.
https://forum.blu-ray.com/showthread.ph ... st12116287
Post by RESET_9999 » Tue Dec 15, 2020 5:12 pm
agneva wrote: Tue Dec 15, 2020 4:41 pm
I think so, I don't see any difference between BL+RPU(profile 8 ) vs dual-track dual-layer MEL(profile 7) on my Sony x700
plus the MEL movies can also be re-encoded. Thank's to @quietvoid rpu extractor.
did you try with profile 8 ? i think DVDFAB still produces profile 5 file which is incorrect for HDR10 BL.
agneva
Post by agneva » Tue Dec 15, 2020 5:45 pm
this makes DVDFab with DV SL, can´t be set.
How can I create Profile 8 with reencoded FEL ?
Of course you can´t see any difference between a empty (M)EL and no EL.
Private Ryan´s FEL is pumping when you look only the FEL on Media Player Classic, looks very strange :lol:
The quality is bad + brightness pumping if you watch it without FEL. The FEL is necassary.
I tried to watch, but after 20min i switched to HDR10.
Today I could convince myself from the real DV Version of Ryan :arrow: its very nice.
calibra3
Post by calibra3 » Tue Dec 15, 2020 5:58 pm
Roberespa wrote: Sun Dec 13, 2020 5:01 pm * Tutorial on how to convert an .iso movie with HDR10 and Dolby Vision to .m2ts *
MakeMKV
tsMuxeR:
ffmpeg
Use tsMuxeR and open "BL_EL_RPU.hevc" To put the audios and subtitles that you mount in a virtual unit, the FULL-UHD Dolby Vision.iso adds 00073.m2ts unchecks the two video tracks (only adds the audio tracks and subtitles) or previously with tsMuxeR you make a DEMUX to simply add the audio tracks and subtitles to the "BL_EL_RPU.hevc" and give it to create a .ts or .m2ts video file (I recommend .m2ts because it is the purest).
and ready.
Hello from Spain Rober.
Please can you tell me how to do if I have two disc for example of hobbx or LOTR???
How I can merge the two disk to do your tutorial?
Post by RESET_9999 » Tue Dec 15, 2020 6:05 pm
agneva wrote: Tue Dec 15, 2020 5:45 pm 1.png
you have to use yusesope tools or demux your dvdfab mp4 file and then remux with the mp4muxer to profile 8.
https://www.makemkv.com/forum/viewtopic ... 970#p96282
you can't ''properly'' re-encode and preserve FEL.
You could re-encode to mel with @quietvoid rpu extractor + x265.exe
https://github.com/quietvoid/dovi_tool/ ... /0.1.0-fix
Post by shawnc22 » Tue Dec 15, 2020 7:07 pm
Ah that's interesting. I didn't know that dvdfab can now produce the same results as mp4muxer and that the ubk90 can actually play these dual track files. Wonder if it can do the same with TS files
agneva
Post by agneva » Tue Dec 15, 2020 9:38 pm
Didn't try .TS yet, just m2ts.
Do you think ts could work with DV DL too?
Post by shawnc22 » Tue Dec 15, 2020 10:04 pm
agneva wrote: Tue Dec 15, 2020 9:38 pm Didn't try .TS yet, just m2ts.
Not sure if anyone's tested, but the x700 can. If the ubk90 can as well, then that potentially adds another device to the list that can play real FEL DV w/lossless audio.
