I need to run AnyDVD HD so MakeMKV can open some DVDs
drfox33
#1 Post by drfox33 » Mon Dec 14, 2020 10:50 pm
It is rare but happens to me when I get some DVDs - MakeMKV cannot open them.
When I try to open them - it accesses the drive and the drive starts blinking but nothing else happens.
It never gets to "Using LibreDrive mode (v06.2 id=AD8D206E4291)" message like with other DVDs.
Also, DVD drive becomes unresponsive - it keeps blinking until I turn it off (it is in USB enclosure).
But if I start AnyDVD HD and it processes the disk - then MakeMKV can open it and I can make an MKV just fine.
It happened recently with all disks of "Body of Proof" TV series that I got from Netflix and today with "Sleepless in Seattle" DVD.
Here is AnyDVD report on the disk:
Summary for drive W: (AnyDVD HD 8.5.0.0, BDPHash.bin 20-03-11)
HL-DT-ST BD-REWH16NS40 1.02
Drive (Hardware) Region: 1
Current profile: DVD-ROM
Media is a DVD.
Booktype: dvd-rom (version 1), Layers: 2 (parallel)
Total size: 3766848 sectors (7357 MBytes)
Video DVD (or CD) label: SLEEPLESS_IN_SEATTLE
Media is CSS protected!
Media is locked to region(s): 1 3!
Video Standard: NTSC
AI scan forced, heuristic scan detected no protection!
Removing annoying menu and intro/outro clips!
Removed 12 annoying menu clips!
Found & removed structural copy protection!
Found & removed RCE protection!
UDF filesystem patched!
Autorun not found on Video DVD.
Removed CSS copy protection!
Bad sector protection not found.
Emulating RPC-2 drive with region 1!
Here is MakeMKV report after this:
MakeMKV v1.15.3 win(x64-release) started
Calculated BUP offset for VTS #0 does not match one in IFO header.
Complex multiplex encountered - 28 cells and 12591 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #1 was added (28 cell(s), 1:44:48)
Complex multiplex encountered - 28 cells and 12592 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #2 was added (28 cell(s), 1:44:48)
Title #3 has length of 790 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #4 has length of 113 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Any thoughts on why the disks are not working out-of-the-box in MakeMKV?
