Download link for makemkv-oss-1.15.4.tar.gz is broken
calinb
Post by calinb » Mon Dec 14, 2020 10:23 pm
The link is broken here:
https://www.makemkv.com/forum/viewtopic.php?f=3&t=224
The correct link should be (delete the "old" in the URL path):
https://www.makemkv.com/download/makemk ... 5.4.tar.gz
calinb
Re: Download link for makemkv-oss-1.15.4.tar.gz is broken
Post by calinb » Mon Dec 14, 2020 10:34 pm
Nope. Despite the filename, the archive link I guessed and provided doesn't produce a correct 1.15.4 oss file structure. It's a misnamed archive of 1.15.3 oss apparently.
Mike will have to fix it.
Post by dcoke22 » Mon Dec 14, 2020 10:38 pm
viewtopic.php?f=3&t=23933
The 1.15.3 version should work fine.
calinb
Post by calinb » Mon Dec 14, 2020 10:41 pm
dcoke22 wrote: Mon Dec 14, 2020 10:38 pm viewtopic.php?f=3&t=23933
Thanks, dcoke22! I'll try it. Guess my 1.15.4 search string wasn't very effective in leading me to the solution.
hornetster
Post by hornetster » Tue Dec 15, 2020 12:29 am
First visit, about to try the software on Linux, and, yes, the link is still broken...
OK to download the older one, but still use the newer ***-bin-1.15.4*** file?
Oh, and where ARE the older versions...?
hook77
Post by hook77 » Wed Dec 16, 2020 11:00 am
the link is still broken, however, no problem to remove "old" from the URL.
I was able to build and install the 1.15.4 w/o any problems.
Funny: The "Info" Dialog says "MakeMKV" and "GUI Version" is 1.15.4, while the "latest version" is 1.15.3.
There was no notification for an update, by the way ...
Regards, hook
Post by d00zah » Tue Sep 26, 2023 10:35 am
eliana78 wrote: Tue Sep 26, 2023 5:11 am ... I'm also having trouble finding the repository for previous versions.
https://www.makemkv.com/download/old/
